주요 콘텐츠로 건너뛰기
Turtle Beach Elite 800 Transmitter Contact Pins Replacement
필요한 것
  1. Turtle Beach Elite 800 Transmitter Contact Pins Replacement, Transmitter Contact Pins: 1 단계, 이미지 2개 중 1개 Turtle Beach Elite 800 Transmitter Contact Pins Replacement, Transmitter Contact Pins: 1 단계, 이미지 2개 중 2개
    • Begin by flipping over the transmitter, and removing the padding from the underside of it. This will reveal the screws to take apart the device.
  2. Turtle Beach Elite 800 Transmitter Contact Pins Replacement: 2 단계, 이미지 3개 중 1개 Turtle Beach Elite 800 Transmitter Contact Pins Replacement: 2 단계, 이미지 3개 중 2개 Turtle Beach Elite 800 Transmitter Contact Pins Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the screws ( 11.27mm Phillips head) and open up the transmitter to reveal the internal components. Carefully pry open the transmitter, and use caution when opening it up as to not sever the wire.
  3. Turtle Beach Elite 800 Transmitter Contact Pins Replacement: 3 단계, 이미지 2개 중 1개 Turtle Beach Elite 800 Transmitter Contact Pins Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the two screws (5.21mm Phillips head) on the board on the top half of the transmitter that is holding the charging pins.
  4. Turtle Beach Elite 800 Transmitter Contact Pins Replacement: 4 단계, 이미지 3개 중 1개 Turtle Beach Elite 800 Transmitter Contact Pins Replacement: 4 단계, 이미지 3개 중 2개 Turtle Beach Elite 800 Transmitter Contact Pins Replacement: 4 단계, 이미지 3개 중 3개
    • Once the screws are removed, desolder the two wires from the board, and then remove it, and the charging pins with it.
    • Take extreme caution when dealing with a soldering iron. Refer to the desoldering guide for tips.
    • Note that for the purposes of this guide we simply clipped the wires connected to the board holding the charging pins.
결론
작성자
2다른 기여자 명과 함께
Johnny Lofton
회원 가입일: 01/18/17
861 평판
안내서 5개를 작성함
댓글 한 개
Where did you get the new contact pins?
Kenneth Roberts - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 16
전체 시간: 1,618
