주요 콘텐츠로 건너뛰기
Turtle Beach Recon 70P Motherboard Replacement
필요한 것
  1. Turtle Beach Recon 70P Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Turtle Beach Recon 70P Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Turtle Beach Recon 70P Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Remove the left ear pad by following the steps from the ear pad replacement guide.
    • Use a spudger to pry up and remove the black plastic cover.
  2. Turtle Beach Recon 70P Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Turtle Beach Recon 70P Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Turtle Beach Recon 70P Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver to remove the two 5 mm screws that secure the motherboard.
  3. Turtle Beach Recon 70P Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Turtle Beach Recon 70P Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Turtle Beach Recon 70P Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • You may need to move the speaker so it does not block the path of the motherboard.
    • Remove the motherboard from the headset by up and away from the volume wheel.
    • Take care not to strain the connections.
  4. Turtle Beach Recon 70P Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Turtle Beach Recon 70P Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Before replacing the motherboard, use flush cutters to cut each wire connected to the motherboard.
    • Cut the wires as close as possible to their connections.
    • Take note of how each component connects to the motherboard.
  5. Turtle Beach Recon 70P Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Turtle Beach Recon 70P Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Prepare your replacement motherboard before continuing.
    • Solder each wire of the new motherboard in the same spots they were originally found.
    • Soldering irons can cause burns, fires and device damage. Always solder in a well-ventilated area.
결론
작성자
4다른 기여자 명과 함께
Austin Hance
회원 가입일: 02/05/24
588 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 12
전체 시간: 254
