주요 콘텐츠로 건너뛰기
Unibody MacBook Pro 15" Glass Replacement
필요한 것
  1. Unibody MacBook Pro 15" Glass Replacement, Prepare a Workspace: 1 단계, 이미지 1개 중 1개
    • Set up a clean workspace and gather all supplies. You will need your Macbook Pro, a new screen, a hair dryer, a screen cleaning cloth, and a suction cup.
  2. Unibody MacBook Pro 15" Glass Replacement, Heat the Edges of the Screen: 2 단계, 이미지 2개 중 1개 Unibody MacBook Pro 15" Glass Replacement, Heat the Edges of the Screen: 2 단계, 이미지 2개 중 2개
    • Use a hair dryer to heat the adhesive around the edges of the screen you are removing.
  3. Unibody MacBook Pro 15" Glass Replacement, Use suction to remove the Screen: 3 단계, 이미지 3개 중 1개 Unibody MacBook Pro 15" Glass Replacement, Use suction to remove the Screen: 3 단계, 이미지 3개 중 2개 Unibody MacBook Pro 15" Glass Replacement, Use suction to remove the Screen: 3 단계, 이미지 3개 중 3개
    • Attach the suction cup found in the iFixit repair kit to the corner of your screen, by gently pressing down until it seals. Lift screen away by pulling up on the suction cup key ring.
  4. Unibody MacBook Pro 15" Glass Replacement, Preparing for the New Screen: 4 단계, 이미지 2개 중 1개 Unibody MacBook Pro 15" Glass Replacement, Preparing for the New Screen: 4 단계, 이미지 2개 중 2개
    • Use a screen cleaning cloth to buff out any marks on your Macbook Pros screen surface.
    • Use a screen cleaning cloth to buff out any marks on the inside of new glass that will be applied.
  5. Unibody MacBook Pro 15" Glass Replacement, Preparing Screen Adhesive: 5 단계, 이미지 2개 중 1개 Unibody MacBook Pro 15" Glass Replacement, Preparing Screen Adhesive: 5 단계, 이미지 2개 중 2개
    • Remove the strips covering the adhesive on the new screen.
    • Heat the new adhesive strips evenly using the hair dryer.
  6. Unibody MacBook Pro 15" Glass Replacement, Applying the New Screen: 6 단계, 이미지 2개 중 1개 Unibody MacBook Pro 15" Glass Replacement, Applying the New Screen: 6 단계, 이미지 2개 중 2개
    • Place the new screen in position. Confirm that the new screen is properly aligned with the edges of the Macbook Pro.
  7. Unibody MacBook Pro 15" Glass Replacement, Attaching the New Screen: 7 단계, 이미지 2개 중 1개 Unibody MacBook Pro 15" Glass Replacement, Attaching the New Screen: 7 단계, 이미지 2개 중 2개
    • Using the screen cleaning cloth carefully press the edges of the screen to seal the adhesive.
  8. Unibody MacBook Pro 15" Glass Replacement, Remove Cover: 8 단계, 이미지 1개 중 1개
    • Peel the protective covering off the new screen.
  9. Unibody MacBook Pro 15" Glass Replacement, Reheat the Adhesive: 9 단계, 이미지 3개 중 1개 Unibody MacBook Pro 15" Glass Replacement, Reheat the Adhesive: 9 단계, 이미지 3개 중 2개 Unibody MacBook Pro 15" Glass Replacement, Reheat the Adhesive: 9 단계, 이미지 3개 중 3개
    • To insure the seal of the adhesive, reheat it again with the hair drying.
  10. Unibody MacBook Pro 15" Glass Replacement, Final Press: 10 단계, 이미지 1개 중 1개
    • Finally, use the screen cleaning cloth and carefully press the edges of the screen one more time.
  11. Unibody MacBook Pro 15" Glass Replacement, You did it!: 11 단계, 이미지 1개 중 1개
    • Enjoy your laptop with it's brand new Glass!
결론
This guide provides all instructions necessary to dismantle and replace a Macbook Pro Screen.
다른 43명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Akh1913
회원 가입일: 10/16/15
1,324 평판
안내서 1개를 작성함
PIRL Gadget Garage PIRL Gadget Garage 회원
Community
9 회원들
안내서 10개를 작성함
20가이드 댓글
How did you know the correct part number for your specific MacBook? Where did you source the glass?
frightanic.com - 답글
I sourced my glass this eBay seller: http://www.ebay.com/usr/beetstech?_trksi...
To find the correct part, I followed iFixit's "ID your Mac" prompts in the parts store, then selected the glass panel from the list of compatible parts.
Hope this helps!
Noah Smith -
Is it useful for internal crack
tiffanyts - 답글
FYI, OWC (Other World Computing, aka macsales.com) has the 15-inch glass for $25, and the 13-inch for $24:
https://eshop.macsales.com/item/Apple/MB... (15-inch)
https://eshop.macsales.com/item/Apple/MB... (13-inch)
…and I just discovered they even have the 17-inch:
One last comment: get the glass as hot as you can!
jiclark - 답글
Does this work for the Late-2013 Retina MacBook Pro (15-inch)?
Brian Shiau - 답글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 113
지난 30일: 417
전체 시간: 136,076
