주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Uniden Dect 6.0 Display Replacement
필요한 것
  1. Uniden Dect 6.0 Display Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Locate the battery compartment on the back of the Uniden home phone.
    • Place your finger on the groove, and pull directly back on the cover to access to the battery.
  2. Uniden Dect 6.0 Display Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the white battery pack from the battery compartment.
  3. Uniden Dect 6.0 Display Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the red-and-black-wired port from the plug directly under the battery compartment.
  4. Uniden Dect 6.0 Display Replacement, Keyboard: 4 단계, 이미지 2개 중 1개 Uniden Dect 6.0 Display Replacement, Keyboard: 4 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove the two .9 mm screws on the back of the device on each side of the battery pack.
  5. Uniden Dect 6.0 Display Replacement: 5 단계, 이미지 1개 중 1개
    • Using your fingers, gently lift and separate the front of the housing from the back housing.
    • Potential for device damage: While separating the back housing from the front, be sure to open from the sides as pictured.
  6. Uniden Dect 6.0 Display Replacement: 6 단계, 이미지 1개 중 1개
    • Gently remove the loose keyboard from the lined gel casing located under the front housing of the front of the phone.
  7. Uniden Dect 6.0 Display Replacement, Gel Casing: 7 단계, 이미지 1개 중 1개
    • To better access the screen, remove the loose gel casing that sits under the keyboard.
  8. Uniden Dect 6.0 Display Replacement: 8 단계, 이미지 1개 중 1개
    • Lift out the attached motherboard piece and turn it sideways to access the side of the phone.
    • Potential for device damage: Use caution to avoid severing the wires that connect the motherboard to the phone.
  9. Uniden Dect 6.0 Display Replacement: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Gently use the tweezers to access the motherboard panel and lift it straight up.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Megan Lawrence
회원 가입일: 01/14/15
534 평판
안내서 5개를 작성함
USF Sarasota-Manatee, Team 1-3, Stewart Winter 2015 USF Sarasota-Manatee, Team 1-3, Stewart Winter 2015 회원
USFSM-STEWART-W15S1G3
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 31
전체 시간: 7,015
