주요 콘텐츠로 건너뛰기
Uniden UTAB71 Battery Replacement
필요한 것
  1. Uniden UTAB71 Battery Replacement, Battery: 1 단계, 이미지 1/2 Uniden UTAB71 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Use a plastic opening tool to undo the clips that attach the two halves of the tablet.
    • Be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Battery Replacement: 2 단계, 이미지 1/1
    • Lift off the tape that holds the speaker wires to the battery
    • Leave the tape off to the side
  3. Uniden UTAB71 Battery Replacement: 3 단계, 이미지 1/1
    • Use a soldering tool to disconnect the two wires (red and black) that connect the battery to the motherboard
    • Note the placement of each colored wire in the motherboard
    • If you have no experience in soldering, please follow this guide
  4. Uniden UTAB71 Battery Replacement: 4 단계, 이미지 1/2 Uniden UTAB71 Battery Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    iOpener
    $12.99
    구매
    • Use a credit card to lift the battery off the back of the tablet
    • Do not put any pressure on the motherboard or any other internal components.
    • The battery attached to the back panel with adhesive. You may need to use a heated iOpener to loosen the adhesive and remove the battery.
결론
Ryan Jewell
회원 가입일: 10/20/16
422 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 5-4, Martin Fall 2016 UMass Dartmouth, Team 5-4, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 8
전체 시간: 346
