주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Universal LCD driver Technique
필요한 것
  1. Universal LCD driver Technique, Universal LCD driver Technique: 1 단계, 이미지 3개 중 1개 Universal LCD driver Technique, Universal LCD driver Technique: 1 단계, 이미지 3개 중 2개 Universal LCD driver Technique, Universal LCD driver Technique: 1 단계, 이미지 3개 중 3개
    • Here is the Toshiba with the water damage and a broken case.
    • The LCD is in good shape and has no cracks.
    • Visible damage to the hinges that lifted the entire top case
    • Four rubber plugs covering some screws.
    • Removing the plugs reveals the Phillips screws.
    댓글 쓰기
  2. Universal LCD driver Technique: 2 단계, 이미지 3개 중 1개 Universal LCD driver Technique: 2 단계, 이미지 3개 중 2개 Universal LCD driver Technique: 2 단계, 이미지 3개 중 3개
    • Remove the one on the left bottom
    • as well as the right bottom
    • Here are the four M3x5mm screws
    댓글 쓰기
  3. Universal LCD driver Technique: 3 단계, 이미지 3개 중 1개 Universal LCD driver Technique: 3 단계, 이미지 3개 중 2개 Universal LCD driver Technique: 3 단계, 이미지 3개 중 3개
    • Use a plastic opening tool, or similar to pop the bezel of the LCD assembly
    • Continue to slide the tool all the way across the top
    • Once the bezel has been released from the tabs, it can be further released be applying some gentle manual pulling
    댓글 쓰기
  4. Universal LCD driver Technique: 4 단계, 이미지 3개 중 1개 Universal LCD driver Technique: 4 단계, 이미지 3개 중 2개 Universal LCD driver Technique: 4 단계, 이미지 3개 중 3개
    • Continue to pull on the sides
    • and finally on the bottom.
    • With all the tabs released the bezel can now be removed
    댓글 쓰기
  5. Universal LCD driver Technique: 5 단계, 이미지 3개 중 1개 Universal LCD driver Technique: 5 단계, 이미지 3개 중 2개 Universal LCD driver Technique: 5 단계, 이미지 3개 중 3개
    • Here is the LCD assembly without the bezel
    • Remove the Phillips screw that connects the LCD frame to the back cover. This is the left one
    • Remove the right one as well
    댓글 쓰기
  6. Universal LCD driver Technique: 6 단계, 이미지 3개 중 1개 Universal LCD driver Technique: 6 단계, 이미지 3개 중 2개 Universal LCD driver Technique: 6 단계, 이미지 3개 중 3개
    • The LCd can now be moved forward and away from the rear cover
    • There are three screws on either side that hold the panel to the frame. Remove those
    • Here are the three M2x4 screws
    댓글 쓰기
  7. Universal LCD driver Technique: 7 단계, 이미지 3개 중 1개 Universal LCD driver Technique: 7 단계, 이미지 3개 중 2개 Universal LCD driver Technique: 7 단계, 이미지 3개 중 3개
    • Remove the three Phillips screws on the right side as well.
    • with the screws removed the panel can now be moved out of the LCd frame. The LCD is still connected by the display cable.
    • Here is the panel number clearly visible. this is an important number and needs to be noted.
    댓글 쓰기
  8. Universal LCD driver Technique: 8 단계, 이미지 3개 중 1개 Universal LCD driver Technique: 8 단계, 이미지 3개 중 2개 Universal LCD driver Technique: 8 단계, 이미지 3개 중 3개
    • Remove the display cable carefully. It is very thin and this particular one had some clear tape holding the cable to the panel. Remove it if it is present and disconnect the cable
    • LCD panel all separated from the laptop.
    • Here is the universal driver board. It also includes a separate PCB for the menu button. The cable is 40cm long and will allow for multiple choices for a custom case
    댓글 쓰기
  9. Universal LCD driver Technique: 9 단계, 이미지 3개 중 1개 Universal LCD driver Technique: 9 단계, 이미지 3개 중 2개 Universal LCD driver Technique: 9 단계, 이미지 3개 중 3개
    • Here is the only shortcoming of this kit as far as I can see it. The menu buttons are on the same side as the cable connector, it will get in the way of placing it in a case. Some re-soldering may be necessary
    • All it takes to connect the driver kit to the LCD panel is to plug it in. The connector is a perfect fit.
    • This kit offers HDMI, DVI and VGA input. I opted for the VGA for testing purpose
    댓글 쓰기
  10. Universal LCD driver Technique: 10 단계, 이미지 2개 중 1개 Universal LCD driver Technique: 10 단계, 이미지 2개 중 2개
    • The LCD driver requires 12Volt to work, I used a spare 12V 1.4A switching power supply. the LCD fired right up and displayed a crisp image.
    • Only shortcoming on this kit, the push buttons for the menus are in the same direction as the cable connector. Otherwise this kit definitely exceeded my expectation.
    댓글 쓰기
결론
Now its time to think about a case for the monitor. Great little project for a rainy day and it does save another LCD panel from the landfill.
취소: 해당 안내서를 완성하지 않았습니다.
다른 13명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
oldturkey03
회원 가입일: 09/29/10
857,065 평판
안내서 123개를 작성함
7가이드 댓글
Hello, Nice work…i have v56 universal board with LP154WX4 (TL) (C1) ..after the firmware is installed …i just get very light blue color display…not able to figure out the problem ? can you please suggest….?
Silas Paine - 답글 공유
Another issue, if it’s like mine, is that the color accuracy (and bit depth?) isn’t too good. I used an LCD out of a top-end 2008 Macbook Pro, so I know the color should be better than it is.
James Nielson - 답글 공유
does the board support 14’’ lcd screens?
VALEN FRANCIA - 답글 공유
that will depend on which board you have and if it is listed as supporting your monitor. The trick here is to match the monitor with a driver board. Always verify this with he vendor.
oldturkey03 - 답글 공유
Same here. In my case I have a pile of LCDs but the problem is most of them are the older type are CCFL backlit.
Unfortunately there aren’t that many applications for a CCFL VGA 14.1” panel but anyone who does come up with one please message me “darnstadium
Andre - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 29
지난 30일: 116
전체 시간: 23,663
