주요 콘텐츠로 건너뛰기
VTech Baby's Learning Laptop LEDs Replacement
필요한 것
  1. VTech Baby's Learning Laptop LEDs Replacement, LEDs: 1 단계, 이미지 1/1
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop LEDs Replacement: 2 단계, 이미지 1/1
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop LEDs Replacement: 3 단계, 이미지 1/2 VTech Baby's Learning Laptop LEDs Replacement: 3 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, unscrew the six 7.3mm screws holding the screen together.
  4. VTech Baby's Learning Laptop LEDs Replacement: 4 단계, 이미지 1/3 VTech Baby's Learning Laptop LEDs Replacement: 4 단계, 이미지 2/3 VTech Baby's Learning Laptop LEDs Replacement: 4 단계, 이미지 3/3
    • With the lid closed, position the device such that the handle is pointing towards you.
    • Using your fingers, gently pry open the cover from the hinge.
    • Attempting to remove the cover while the lid is still open may cause unwanted damage to the device.
  5. VTech Baby's Learning Laptop LEDs Replacement: 5 단계, 이미지 1/1
    • Remove two 6.0mm screws from the LED array using a Phillips #0 screwdriver.
  6. VTech Baby's Learning Laptop LEDs Replacement: 6 단계, 이미지 1/1
    • Pickup the array by the opening in the center of the board.
    • Remove the faulty LEDs by desoldering each from the board. You may refer to this soldering guide if necessary.
    • Movement of the array will be limited as it is still attached to the main device board.
결론
Christopher Kourmoulakis
회원 가입일: 09/03/15
373 평판
안내서 3개 작성하였습니다
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G2
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 945
