주요 콘텐츠로 건너뛰기
VTech CS6719-2 Speaker Replacement
필요한 것
  1. VTech CS6719-2 Speaker Replacement, Battery: 1 단계, 이미지 2개 중 1개 VTech CS6719-2 Speaker Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Push down on the battery cover in the direction of the arrow located on the back of the phone.
  2. VTech CS6719-2 Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the battery cover off of the back of the phone.
  3. VTech CS6719-2 Speaker Replacement: 3 단계, 이미지 1개 중 1개
    • Unplug the battery input cable.
  4. VTech CS6719-2 Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the battery out of the back of the phone.
  5. VTech CS6719-2 Speaker Replacement, Circuit Board: 5 단계, 이미지 2개 중 1개 VTech CS6719-2 Speaker Replacement, Circuit Board: 5 단계, 이미지 2개 중 2개
    • Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
  6. VTech CS6719-2 Speaker Replacement: 6 단계, 이미지 1개 중 1개
    • Use the plastic opening tool and spudger to pry the back side of the phone off.
  7. VTech CS6719-2 Speaker Replacement: 7 단계, 이미지 2개 중 1개 VTech CS6719-2 Speaker Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the two 9mm screws located inside the back cover at the top.
  8. VTech CS6719-2 Speaker Replacement, Speaker: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Locate the metal shaped U clip holding the speaker on. Pull up and towards the top of the phone with the flat head tweezers.
    • The clip is loose, it could fall out.
  9. VTech CS6719-2 Speaker Replacement: 9 단계, 이미지 1개 중 1개
    • Lift speaker out.
  10. VTech CS6719-2 Speaker Replacement: 10 단계, 이미지 1개 중 1개
    • Heat up solder joint on the circuit board where the speaker wires are connected.
  11. VTech CS6719-2 Speaker Replacement: 11 단계, 이미지 1개 중 1개
    • Refer to How To Solder and Desolder Connections 연결부 납땜 및 납제거 방법
    • Note: Ensure the old solder joint is removed.
    • Caution: Soldering iron and joint will become very ho
결론
작성자
6다른 기여자 명과 함께
Benjamin Field
회원 가입일: 02/08/16
270 평판
안내서 2개를 작성함
IUPUI, Team 1-4, Baechle Spring 2016 IUPUI, Team 1-4, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S1G4
4 회원들
안내서 16개를 작성함
2가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 22
전체 시간: 1,046
