주요 콘텐츠로 건너뛰기
VTech Learning Tunes Karaoke Speaker Replacement
필요한 것
  1. VTech Learning Tunes Karaoke Speaker  Replacement, Speaker: 1 단계, 이미지 1/1
    • To remove the battery door, loosen the screw using a Flathead screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Learning Tunes Karaoke Speaker  Replacement: 2 단계, 이미지 1/2 VTech Learning Tunes Karaoke Speaker  Replacement: 2 단계, 이미지 2/2
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Speaker  Replacement: 3 단계, 이미지 1/1
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Speaker  Replacement: 4 단계, 이미지 1/2 VTech Learning Tunes Karaoke Speaker  Replacement: 4 단계, 이미지 2/2
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Carefully place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Speaker  Replacement: 5 단계, 이미지 1/2 VTech Learning Tunes Karaoke Speaker  Replacement: 5 단계, 이미지 2/2
    • Remove two 7.9 mm Phillips #1 screws on the speaker cover.
    • After removing the screws, remove the black plastic speaker cover to expose the speaker.
  6. VTech Learning Tunes Karaoke Speaker  Replacement: 6 단계, 이미지 1/1
    • Desolder the speaker at the solder points to remove.
    • Learn more about soldering and desoldering connections here.
결론
Gamuchirai Chifamba
회원 가입일: 02/09/16
249 평판
안내서 2개 작성하였습니다
USF Tampa, Team 7-2, Cheng Spring 2016 USF Tampa, Team 7-2, Cheng Spring 2016 회원
USFT-CHENG-S16S7G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 708
