주요 콘텐츠로 건너뛰기
VTech Learning Tunes Karaoke Volume Switch Replacement
필요한 것
  1. VTech Learning Tunes Karaoke Volume Switch Replacement, Volume Switch: 1 단계, 이미지 1/1
    • To remove the battery door, loosen the screw using a Flathead screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Learning Tunes Karaoke Volume Switch Replacement: 2 단계, 이미지 1/2 VTech Learning Tunes Karaoke Volume Switch Replacement: 2 단계, 이미지 2/2
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Volume Switch Replacement: 3 단계, 이미지 1/1
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Volume Switch Replacement: 4 단계, 이미지 1/2 VTech Learning Tunes Karaoke Volume Switch Replacement: 4 단계, 이미지 2/2
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Volume Switch Replacement: 5 단계, 이미지 1/2 VTech Learning Tunes Karaoke Volume Switch Replacement: 5 단계, 이미지 2/2
    • Using a Phillips PH1 screwdriver, remove the two 7.9 mm volume switch board screws.
  6. VTech Learning Tunes Karaoke Volume Switch Replacement: 6 단계, 이미지 1/1
    • Once the screws have been removed, carefully move the volume switch board.
  7. VTech Learning Tunes Karaoke Volume Switch Replacement: 7 단계, 이미지 1/1
결론
Lezette Leuterio
회원 가입일: 02/09/16
101 평판
안내서 1개 작성함
USF Tampa, Team 7-2, Cheng Spring 2016 USF Tampa, Team 7-2, Cheng Spring 2016 회원
USFT-CHENG-S16S7G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 252
