주요 콘텐츠로 건너뛰기
VTech Little Apps Tablet Battery Internal Wiring Replacement
필요한 것
  1. VTech Little Apps Tablet Battery Internal Wiring Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the 9.9 mm screw covering the batteries with a PH1 driver head.
  2. VTech Little Apps Tablet Battery Internal Wiring Replacement: 2 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to pry the batteries out of their holding.
    • If replacing your batteries with new ones, be careful to insert them as indicated on the device.
  3. VTech Little Apps Tablet Battery Internal Wiring Replacement, Back Cover: 3 단계, 이미지 2개 중 1개 VTech Little Apps Tablet Battery Internal Wiring Replacement, Back Cover: 3 단계, 이미지 2개 중 2개
    • Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
    • Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
  4. VTech Little Apps Tablet Battery Internal Wiring Replacement: 4 단계, 이미지 2개 중 1개 VTech Little Apps Tablet Battery Internal Wiring Replacement: 4 단계, 이미지 2개 중 2개
    • Gently remove the back cover then flip it 180 degrees so that the back cover of the device is now face-down.
    • Proceed with caution as there are wires attaching the back cover to the front cover of the device that could be easily detached.
  5. VTech Little Apps Tablet Battery Internal Wiring Replacement, Battery Internal Wiring: 5 단계, 이미지 1개 중 1개
    • Visually inspect the wires connecting the motherboard to the batteries, looking for damage.
    • Possible damage includes: lead disconnections, wire fraying, and complete wire disconnections.
  6. VTech Little Apps Tablet Battery Internal Wiring Replacement: 6 단계, 이미지 1개 중 1개
    • Desolder the internal wire leads connected to the batteries, making sure to remove the positive (red) wire first, and the negative (black) wire second.
    • For assistance with soldering, see this Guide.
  7. VTech Little Apps Tablet Battery Internal Wiring Replacement: 7 단계, 이미지 1개 중 1개
    • Next desolder the same black and red internal wire leads connected to the motherboard.
    • The order does not matter for this step.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Johnnie Cairns
회원 가입일: 02/10/16
522 평판
안내서 4개를 작성함
USF Tampa, Team 2-6, Sullivan Spring 2016 USF Tampa, Team 2-6, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S2G6
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 20
전체 시간: 1,389
