주요 콘텐츠로 건너뛰기
VTech Spin and Learn Color Flashlight Speaker Replacement
필요한 것
  1. VTech Spin and Learn Color Flashlight Speaker Replacement, Battery Housing: 1 단계, 이미지 1/2 VTech Spin and Learn Color Flashlight Speaker Replacement, Battery Housing: 1 단계, 이미지 2/2
    • Locate the battery housing on the back of the flashlight as pictured.
    • Unscrew the single 8 mm Phillips #1 screw.
    • The screw will stay attached to the cover that will be removed.
    • Lift the battery housing cover to reveal the battery terminals. Remove the batteries.
  2. VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker Housing: 2 단계, 이미지 1/3 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker Housing: 2 단계, 이미지 2/3 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker Housing: 2 단계, 이미지 3/3
    • Locate the light blue speaker housing on the bottom of the flashlight.
    • Remove the three 6 mm Phillips #0 screws.
    • Once the screws have been removed, pull the housing away from the yellow body of the flashlight. Be careful not to disconnect the white wires from the speaker, unless speaker replacement is required.
  3. VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker: 3 단계, 이미지 1/3 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker: 3 단계, 이미지 2/3 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker: 3 단계, 이미지 3/3
    • Locate the wires connected to the speaker indicated by the red circles in image one.
    • Desolder the wires from the connection point circled in the second image. If you're unsure of how to use the soldering station, use iFixit's guide to soldering and desoldering to help.
    • Remove the 2 highlighted 4mm Phillips #0 screws in image three.
결론
Nathaniel Troyer
회원 가입일: 08/27/15
441 평판
안내서 4개 작성하였습니다
USF Tampa, Team 2-6, Blackwell Fall 2015 USF Tampa, Team 2-6, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S2G6
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 460
