주요 콘텐츠로 건너뛰기
VTechCS6719-16 Speaker Replacement
필요한 것
  1. VTechCS6719-16 Speaker Replacement, Speaker: 1 단계, 이미지 1개 중 1개
    • Remove the sliding cover on the back of the phone case.
  2. VTechCS6719-16 Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Now remove the battery by lifting it and removing the two pin cable.
  3. VTechCS6719-16 Speaker Replacement: 3 단계, 이미지 1개 중 1개
    • Unscrew the two 10mm screws on the back of the phone base.
  4. VTechCS6719-16 Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Using the metal spudger edge along the phone and locate the hooks and latches.
    • Locating each of them apply a light but firm lifting force to release the front and back case.
  5. VTechCS6719-16 Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • The front case should now be freed.
    • Put the front case aside for later.
  6. VTechCS6719-16 Speaker Replacement: 6 단계, 이미지 1개 중 1개
    • There are two 10mm screws located at the top of the circuit board.
    • Unscrewing the screws allows for access to the speaker.
  7. VTechCS6719-16 Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Flipping the circuit board will expose the speaker rested in the white LCD base.
    • Gently using the scoop end of the spudger will free the speaker from the dock.
    • Careful not to jerk the speaker as it is still attached to the board.
  8. VTechCS6719-16 Speaker Replacement: 8 단계, 이미지 1개 중 1개
    • The last portion of this will require soldering skills. Simply solder the speaker from the board and replace with desired speaker.
    • If this is your first time soldering, check out this useful soldering guide.
결론
작성자
3다른 기여자 명과 함께
Charles montes
회원 가입일: 10/20/16
513 평판
안내서 5개를 작성함
UMass Dartmouth, Team 5-5, Martin Fall 2016 UMass Dartmouth, Team 5-5, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G5
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 293
