주요 콘텐츠로 건너뛰기
Velocity Micro Cruz Speaker Replacement
필요한 것
  1. Velocity Micro Cruz Speaker Replacement, Remove the Back: 1 단계, 이미지 1/1
    • Using one of the plastic opening tools, separate the plastic back from the tablet in one spot.
    • Gently work the tool around the diameter of the tablet until the back pops completely off.
  2. Velocity Micro Cruz Speaker Replacement, Remove All Screws: 2 단계, 이미지 1/2 Velocity Micro Cruz Speaker Replacement, Remove All Screws: 2 단계, 이미지 2/2
    • Use the screwdrivers to remove all the screws.
    • Ensure that all screws are removed before moving on to the next step.
  3. Velocity Micro Cruz Speaker Replacement, Remove LCD Connector: 3 단계, 이미지 1/1
    • Remove the bottom LCD connector by gently pulling it away from the motherboard.
  4. Velocity Micro Cruz Speaker Replacement, Separate the Frame from the Housing: 4 단계, 이미지 1/1
    • Identify the speaker wires.
    • Use a plastic opening tool to gently pry underneath the frame of the grey plastic frame until it completely separates from the housing.
  5. Velocity Micro Cruz Speaker Replacement, Remove and Replace the Speaker: 5 단계, 이미지 1/1
    • Use the wire cutters to clip the speaker wires in the middle
    • Use a plastic opening tool to remove the speaker.
    • Insert the new speaker in its place and solder the old and new wires together.
    • For soldering help, check out iFixit's How to Solder and Desolder Connections guide.
결론
T Smith
회원 가입일: 11/02/16
205 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 7
전체 시간: 116
