주요 콘텐츠로 건너뛰기
Velocity Micro Cruz T301 Battery Replacement
필요한 것
  1. Velocity Micro Cruz T301 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Insert the plastic iFixit opening tool into the SD port. Orient the iFixit opening tool so that the edge faces the rear panel.
  2. Velocity Micro Cruz T301 Battery Replacement: 2 단계, 이미지 1/1
    • Use the iFixit opening tools to pry open a gap between the tablet and rear panel.
  3. Velocity Micro Cruz T301 Battery Replacement: 3 단계, 이미지 1/2 Velocity Micro Cruz T301 Battery Replacement: 3 단계, 이미지 2/2
    • Move the small tool opener around the rear panel to free the 12 clips.
  4. Velocity Micro Cruz T301 Battery Replacement: 4 단계, 이미지 1/1
    • Remove the four screws in the metal battery housing using the Phillips #0 screwdriver.
  5. Velocity Micro Cruz T301 Battery Replacement: 5 단계, 이미지 1/1
    • Disconnect the battery using the spudger.
  6. Velocity Micro Cruz T301 Battery Replacement: 6 단계, 이미지 1/1
    • Lift the battery out of its place with a nylon spudger.
    • This photo shows the use of an incorrect tool. Always use an ESD safe tool, like the nylon spudger, when dealing with delicate components.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ali Rashid Al Araimi
회원 가입일: 10/05/16
371 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-6, Cagle Fall 2016 USF Tampa, Team 1-6, Cagle Fall 2016 회원
USFT-CAGLE-F16S1G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 531
