이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
In every tablet, the screen is the most vulnerable component of the device and is prone to damage. If the screen on your tablet is cracked or if the images aren’t properly showing up on your screen, then the screen needs to be replaced.
필요한 것
Using a plastic opening tool, slowly pry along the seam running along the edge of the device until the back case snaps free.
Remove the back case.
Remove all 5 screws from their respective holes using the Phillips #00 screwdriver.
Remove the speaker from the device.
Using a guitar pick or a metal spudger, remove the old screen from the device from the back of the tablet.
다른 한 분이 해당 안내서를 완성하였습니다.
