소개
Kratzer in Brillengläsern können das klare Sehen verhindern. Wie du solche Kratzer in der Glasoberfläche behandelst und bestenfalls wieder verschwinden läßt, findest du in den folgenden einfachen Schritten.
필요한 것
Lege die Brille, das Wachs und ein Tuch auf eine flache Oberfläche.
Bei besonders tiefen und hartnäckigen Kratzer muss diese Prozedur möglicherweise mehrfach angewendet werden.
다른 56명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 24개
Stupid is as stupid does! Think about it. A scratch is a certain width, when you polish it you are just grinding off the edges of the scratch and actually making it wider. So unless you are capable of removing all the surrounding material to the depth of the deepest part of the scratch AND maintaining the profile to within a very very small tolerance then this just WILL NOT work. Filling the scratch with wax cannot work either as wax does not have the same refractive index as the lens material. Conclusion: take care of your glasses and if you are careless enough to damage them it's your own fault, accept responsibility and replace them.
This sounds like "I've not tried this but I've thought about it for a few minutes and this is what I think will happen". Very short on evidence.
steve -
Wow!!! Just couldn’t help yourself could you. Perhaps you’ve heard “If you can’t say something nice say nothing at all”! Grow up without doing it at someone elses expense.
Yaya -
Obviously, this person has never made a mistake and is absolutely perfect in every way.
