주요 콘텐츠로 건너뛰기
Visual Land Prestige Elite 7Q Speaker Replacement
필요한 것
  1. Visual Land Prestige Elite 7Q Speaker Replacement, Speaker: 1 단계, 이미지 1/2 Visual Land Prestige Elite 7Q Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • At the bottom of the tablet, remove the two 3.6mm screws with a Phillips #000 screwdriver.
  2. Visual Land Prestige Elite 7Q Speaker Replacement: 2 단계, 이미지 1/2 Visual Land Prestige Elite 7Q Speaker Replacement: 2 단계, 이미지 2/2
    • Wedge a plastic opening tool into the edges of the tablet to pry it open.
  3. Visual Land Prestige Elite 7Q Speaker Replacement: 3 단계, 이미지 1/3 Visual Land Prestige Elite 7Q Speaker Replacement: 3 단계, 이미지 2/3 Visual Land Prestige Elite 7Q Speaker Replacement: 3 단계, 이미지 3/3
    • Soldering iron may be dangerous for inexperienced users. For additional information on how to use a soldering iron, click here.
    • Use a soldering iron to detach the speaker wires from the motherboard.
  4. Visual Land Prestige Elite 7Q Speaker Replacement: 4 단계, 이미지 1/3 Visual Land Prestige Elite 7Q Speaker Replacement: 4 단계, 이미지 2/3 Visual Land Prestige Elite 7Q Speaker Replacement: 4 단계, 이미지 3/3
    • Use a curved metal spudger to remove the speaker from the back case.
    • The speaker is held in place by an adhesive and can be difficult to remove.
결론
Sabrina Scholten
회원 가입일: 09/22/16
621 평판
안내서 6개 작성하였습니다
UC Davis, Team 2-1, Oliver Fall 2016 UC Davis, Team 2-1, Oliver Fall 2016 회원
UCD-OLIVER-F16S2G1
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 176
