주요 콘텐츠로 건너뛰기
Visual Land Prestige Elite 9Q Battery Replacement
필요한 것
  1. Visual Land Prestige Elite 9Q Battery  Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Using the large plastic opening tool, start along a side of the device and apply light pressure in the seam between the top and bottom outer covers.
    • Maneuver the smaller plastic opening tool at the spot of the large opening tool and slowly slide along the edge.
    • You should feel each plastic connection begin to loosen.
  2. Visual Land Prestige Elite 9Q Battery  Replacement: 2 단계, 이미지 1개 중 1개
    • Move tool around each connection, and continue around the device until all connections have been loosened.
    • The user risks damaging the connections if tool is slid to fast.
  3. Visual Land Prestige Elite 9Q Battery  Replacement: 3 단계, 이미지 2개 중 1개 Visual Land Prestige Elite 9Q Battery  Replacement: 3 단계, 이미지 2개 중 2개
    • Once all connections have been loosened and using a soft surface, place the device onto its screen, and lift gently on the outer casing.
    • Open the casing and lay as shown keeping the speaker wires loose.
  4. Visual Land Prestige Elite 9Q Battery  Replacement: 4 단계, 이미지 2개 중 1개 Visual Land Prestige Elite 9Q Battery  Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use wide tip tweezers to gently remove the three pieces of tape attached to battery.
    • Once the tape has been removed, the battery will be free from the tablet except for the wired connections to the circuit board.
    • Be careful not to severely damage the tape as this is what will hold the battery in place.
    • Mark where the positive (red) and negative (black) wires are on the circuit board.
    • Markings will be used for reassembly.
  5. Visual Land Prestige Elite 9Q Battery  Replacement: 5 단계, 이미지 2개 중 1개 Visual Land Prestige Elite 9Q Battery  Replacement: 5 단계, 이미지 2개 중 2개
    • Before disconnecting battery, review Soldering Tips to ensure proper soldering.
    • Use soldering iron to remove +(red) battery lead.
    • Touch the positive wire to a metal surface acting as a ground to discharge the battery. Depending on the charge level of the battery, it may take up to 30 seconds to insure that it is fully discharged.
    • 'Ensure that the wires and solder do not touch each other, for this will damage the device
    • Remove the -(black) battery lead.
    • Remove and discard the old battery. Insert new battery and solder the positive and then the negative terminals to the circuit board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
LAWRENCE SMITH
회원 가입일: 07/19/16
108 평판
안내서 1개를 작성함
University of Memphis, Team 1-1, Kim SU 2016 University of Memphis, Team 1-1, Kim SU 2016 회원
UM-KIM-SU16S1G1
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 2,401
