소개
Before starting this guide its important to note that the speaker replacement requires soldering. Don't know how to solder? Don't worry! You can learn how right here.
필요한 것
Using the large plastic opening tool, start along a side of the device and apply light pressure in the seam between the top and bottom outer covers.
Maneuver the smaller plastic opening tool at the spot of the large opening tool and slowly slide along the edge.
Before disconnecting the speaker, refer to Soldering Tips for proper soldering instructions.
Use a soldering iron the remove the speaker wires.
