주요 콘텐츠로 건너뛰기
Vizio SmartCast Crave 360 Battery Replacement
필요한 것
  1. Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: 1 단계, 이미지 2개 중 1개 Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: 1 단계, 이미지 2개 중 2개
    • Orient the speaker so that the bottom faces up.
    • Peel the rubber ring off of the bottom using the spudger.
  2. Vizio SmartCast Crave 360 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
  3. Vizio SmartCast Crave 360 Battery Replacement: 3 단계, 이미지 2개 중 1개 Vizio SmartCast Crave 360 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Lift the gray power port and move it to the side to reveal the bass.
    • Do not touch the wire that runs from the power port to the bottom of the bass component.
  4. Vizio SmartCast Crave 360 Battery Replacement, Bass: 4 단계, 이미지 2개 중 1개 Vizio SmartCast Crave 360 Battery Replacement, Bass: 4 단계, 이미지 2개 중 2개
    • Remove the collar that wraps around the bass component.
    • Once the collar is removed, the speaker should appear similar to the speaker shown in the second photo.
  5. Vizio SmartCast Crave 360 Battery Replacement: 5 단계, 이미지 3개 중 1개 Vizio SmartCast Crave 360 Battery Replacement: 5 단계, 이미지 3개 중 2개 Vizio SmartCast Crave 360 Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the four 10 mm screws with that connect the bass to the rest of the speaker using a Phillips #000 screwdriver.
    • Take the bass component out of the speaker.
    • Disconnect the wiring that runs into the bass component.
    • The bass is now removed.
  6. Vizio SmartCast Crave 360 Battery Replacement, Battery: 6 단계, 이미지 2개 중 1개 Vizio SmartCast Crave 360 Battery Replacement, Battery: 6 단계, 이미지 2개 중 2개
    • Flip the speaker to access the top.
    • Remove the eight 10 mm screws from the plastic disc inside the grey speaker cage using a Phillips #000 screwdriver.
    • Remove the plastic disc from the speaker cage.
  7. Vizio SmartCast Crave 360 Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the grey speaker cage to reveal a black plastic cylinder that contains the battery.
  8. Vizio SmartCast Crave 360 Battery Replacement: 8 단계, 이미지 2개 중 1개 Vizio SmartCast Crave 360 Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the wire that connects the motherboard to the battery.
  9. Vizio SmartCast Crave 360 Battery Replacement: 9 단계, 이미지 2개 중 1개 Vizio SmartCast Crave 360 Battery Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the motherboard and battery from the plastic cylinder.
  10. Vizio SmartCast Crave 360 Battery Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the four 5 mm screws from the motherboard using a Phillips #000 screwdriver.
  11. Vizio SmartCast Crave 360 Battery Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the motherboard from the battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Pavani Lopez Leon
회원 가입일: 09/06/22
433 평판
안내서 3개를 작성함
댓글 한 개
Any other way to charge the battery without the charging station or is there a compatible charging station?
Trading Azteca - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 60
전체 시간: 1,563
