주요 콘텐츠로 건너뛰기
Vtech Innotab 3 Microphone Replacement
필요한 것
  1. Vtech Innotab 3 Microphone Replacement, Rear Panel: 1 단계, 이미지 3개 중 1개 Vtech Innotab 3 Microphone Replacement, Rear Panel: 1 단계, 이미지 3개 중 2개 Vtech Innotab 3 Microphone Replacement, Rear Panel: 1 단계, 이미지 3개 중 3개
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
  2. Vtech Innotab 3 Microphone Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
  3. Vtech Innotab 3 Microphone Replacement: 3 단계, 이미지 3개 중 1개 Vtech Innotab 3 Microphone Replacement: 3 단계, 이미지 3개 중 2개 Vtech Innotab 3 Microphone Replacement: 3 단계, 이미지 3개 중 3개
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
  4. Vtech Innotab 3 Microphone Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
  5. Vtech Innotab 3 Microphone Replacement, Microphone: 5 단계, 이미지 3개 중 1개 Vtech Innotab 3 Microphone Replacement, Microphone: 5 단계, 이미지 3개 중 2개 Vtech Innotab 3 Microphone Replacement, Microphone: 5 단계, 이미지 3개 중 3개
    • Remove the four 7.6 mm screws using a PH00 screwdriver.
    • Lift up the circuit board from the device.
  6. Vtech Innotab 3 Microphone Replacement: 6 단계, 이미지 3개 중 1개 Vtech Innotab 3 Microphone Replacement: 6 단계, 이미지 3개 중 2개 Vtech Innotab 3 Microphone Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • To replace the microphone, desolder the two connections that connect the speaker to the device.
    • Use tweezers to keep the microphone steady as you desolder the connections.
    • This is a tricky step. Refer to this guide to learn how to solder: How To Solder and Desolder Connections
결론
작성자
3다른 기여자 명과 함께
Zach Diviney
회원 가입일: 03/11/15
419 평판
안내서 4개를 작성함
Colorado Springs, Team 5-4, Panko Spring 2015 Colorado Springs, Team 5-4, Panko Spring 2015 회원
UCCS-PANKO-S15S5G4
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 477
