주요 콘텐츠로 건너뛰기
Vtech Kidibeats Drum Set Volume Switch Replacement
필요한 것
  1. Vtech Kidibeats Drum Set Volume Switch Replacement, Back Panel: 1 단계, 이미지 1/1
    • Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
  2. Vtech Kidibeats Drum Set Volume Switch Replacement: 2 단계, 이미지 1/1
    • To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
    • You can also use a small coin to loosen the screw.
  3. Vtech Kidibeats Drum Set Volume Switch Replacement: 3 단계, 이미지 1/1
    • Using your fingers, pry open and remove the back battery panel.
  4. Vtech Kidibeats Drum Set Volume Switch Replacement: 4 단계, 이미지 1/1
    • Use your fingers to remove each battery from its housing.
  5. Vtech Kidibeats Drum Set Volume Switch Replacement: 5 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, loosen and remove the six 14 mm screws.
  6. Vtech Kidibeats Drum Set Volume Switch Replacement: 6 단계, 이미지 1/2 Vtech Kidibeats Drum Set Volume Switch Replacement: 6 단계, 이미지 2/2
    • With your hands, separate the bottom panel from the drum set.
    • When removing the bottom panel, be careful not to pull too hard in order to prevent damaging the connections from the motherboard to the speaker and power source.
  7. Vtech Kidibeats Drum Set Volume Switch Replacement, Volume Switch: 7 단계, 이미지 1/1
    • Loosen and remove the two 8 mm screws using a Phillips #00 screwdriver.
  8. Vtech Kidibeats Drum Set Volume Switch Replacement: 8 단계, 이미지 1/1
    • Use your fingers to gently remove the volume switch from its setting.
  9. Vtech Kidibeats Drum Set Volume Switch Replacement: 9 단계, 이미지 1/1
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Aaron Klementowski
회원 가입일: 02/09/16
820 평판
안내서 6개 작성하였습니다
USF Tampa, Team 2-8, Cagle Spring 2016 USF Tampa, Team 2-8, Cagle Spring 2016 회원
USFT-CAGLE-S16S2G8
2 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 620
