소개
A faulty volume switch can often lead to distorted audio or even no audio at all. This guide is designed to show how to correctly replace the volume switch for your drum set in order to restore sound and proper function.
필요한 것
Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
