주요 콘텐츠로 건너뛰기
Vtech Kidizoom Smart Watch DX Battery Replacement
필요한 것
  1. Vtech Kidizoom Smart Watch DX Battery Replacement, Master Switch: 1 단계, 이미지 1개 중 1개
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
  2. Vtech Kidizoom Smart Watch DX Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
  3. Vtech Kidizoom Smart Watch DX Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Battery Replacement: 4 단계, 이미지 2개 중 1개 Vtech Kidizoom Smart Watch DX Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the master switch from the circuit board.
  5. Vtech Kidizoom Smart Watch DX Battery Replacement, Circuit Board: 5 단계, 이미지 2개 중 1개 Vtech Kidizoom Smart Watch DX Battery Replacement, Circuit Board: 5 단계, 이미지 2개 중 2개
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
  6. Vtech Kidizoom Smart Watch DX Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Battery Replacement: 8 단계, 이미지 1개 중 1개
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Battery Replacement: 9 단계, 이미지 1개 중 1개
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
  10. Vtech Kidizoom Smart Watch DX Battery Replacement, Battery: 10 단계, 이미지 2개 중 1개 Vtech Kidizoom Smart Watch DX Battery Replacement, Battery: 10 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, gently pry the edges of the battery away from from the circuit board.
    • There is a thin layer of adhesive holding the battery to the circuit board. This will remain sticky after prying.
  11. Vtech Kidizoom Smart Watch DX Battery Replacement: 11 단계, 이미지 1개 중 1개
    • De-solder the red battery wire from the circuit board.
  12. Vtech Kidizoom Smart Watch DX Battery Replacement: 12 단계, 이미지 1개 중 1개
    • Repeat the de-soldering for the black (ground) wire.
  13. Vtech Kidizoom Smart Watch DX Battery Replacement: 13 단계, 이미지 1개 중 1개
    • Pull the battery free, and wait for the solder to cool before handling further.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Navin Ramkishun
회원 가입일: 01/20/16
271 평판
안내서 1개를 작성함
USF Tampa, Team 10-6, Remmell Spring 2016 USF Tampa, Team 10-6, Remmell Spring 2016 회원
USFT-REMMELL-S16S10G6
4 회원들
안내서 12개를 작성함
1가이드 댓글
Where did you bought the battery?
funkysoulbrother - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 54
전체 시간: 9,772
