주요 콘텐츠로 건너뛰기
Vtech Kidizoom Smart Watch DX Circuit Board Replacement
필요한 것
  1. Vtech Kidizoom Smart Watch DX Circuit Board Replacement, Master Switch: 1 단계, 이미지 1개 중 1개
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
  2. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
  3. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 3 단계, 이미지 1개 중 1개
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 4 단계, 이미지 2개 중 1개 Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the master switch from the circuit board.
  5. Vtech Kidizoom Smart Watch DX Circuit Board Replacement, Circuit Board: 5 단계, 이미지 2개 중 1개 Vtech Kidizoom Smart Watch DX Circuit Board Replacement, Circuit Board: 5 단계, 이미지 2개 중 2개
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
  6. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 7 단계, 이미지 1개 중 1개
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 8 단계, 이미지 1개 중 1개
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 9 단계, 이미지 1개 중 1개
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jordan RiberSmith
회원 가입일: 01/20/16
797 평판
안내서 2개를 작성함
USF Tampa, Team 10-6, Remmell Spring 2016 USF Tampa, Team 10-6, Remmell Spring 2016 회원
USFT-REMMELL-S16S10G6
4 회원들
안내서 12개를 작성함
2가이드 댓글
Where can I buy the circuit board ?? Please send me a link or just post it please. Thanks
Jamar Mckay - 답글
Where can I buy replacement and how much should it cost?
Marisol Pelayo - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 45
전체 시간: 10,861
