주요 콘텐츠로 건너뛰기
WRS315SDHW Control Board Replacement
필요한 것
  1. WRS315SDHW Control Board Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: 2 단계, 이미지 2개 중 1개 WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: 2 단계, 이미지 2개 중 2개
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the two dispenser panels.
  3. WRS315SDHW Control Board Replacement, Remove the dispenser panels: 3 단계, 이미지 3개 중 1개 WRS315SDHW Control Board Replacement, Remove the dispenser panels: 3 단계, 이미지 3개 중 2개 WRS315SDHW Control Board Replacement, Remove the dispenser panels: 3 단계, 이미지 3개 중 3개
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. WRS315SDHW Control Board Replacement, Unfasten the control board: 4 단계, 이미지 1개 중 1개
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the control board.
  5. WRS315SDHW Control Board Replacement: 5 단계, 이미지 3개 중 1개 WRS315SDHW Control Board Replacement: 5 단계, 이미지 3개 중 2개 WRS315SDHW Control Board Replacement: 5 단계, 이미지 3개 중 3개
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. WRS315SDHW Control Board Replacement, Disconnect the control board: 6 단계, 이미지 3개 중 1개 WRS315SDHW Control Board Replacement, Disconnect the control board: 6 단계, 이미지 3개 중 2개 WRS315SDHW Control Board Replacement, Disconnect the control board: 6 단계, 이미지 3개 중 3개
    • Disconnect the large connector attached to the right edge of the control board.
  7. WRS315SDHW Control Board Replacement: 7 단계, 이미지 2개 중 1개 WRS315SDHW Control Board Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the small connector attached to the left edge of the control board.
  8. WRS315SDHW Control Board Replacement, Remove the control board: 8 단계, 이미지 1개 중 1개
    • Remove the control board.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,945 평판
안내서 89개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 635
