주요 콘텐츠로 건너뛰기
Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement
필요한 것
  1. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Safety precautions: 1 단계, 이미지 2개 중 1개 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Safety precautions: 1 단계, 이미지 2개 중 2개
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Loosen the handle: 2 단계, 이미지 2개 중 1개 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Loosen the handle: 2 단계, 이미지 2개 중 2개
    • For ease of access, swing the transport wheels underneath the plate compactor before you begin.
    • Use a 3/4" wrench to remove the two nuts securing the handle.
    • Use your palm to push against the shockmount to prevent it from slipping.
    • Remove the nuts and washers and retain them for reassembly.
  3. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Lower the handle: 3 단계, 이미지 3개 중 1개 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Lower the handle: 3 단계, 이미지 3개 중 2개 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Lower the handle: 3 단계, 이미지 3개 중 3개
    • Tilt the guide handle forward to pivot the shockmount bolts out of the base grooves.
    • Slide the guide handle down enough to access the shockmounts.
  4. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Remove the shockmount: 4 단계, 이미지 2개 중 1개 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Remove the shockmount: 4 단계, 이미지 2개 중 2개
    • Pull the shockmount out of the guide handle.
결론
Arthur Shi
회원 가입일: 01/03/18
313,333 평판
안내서 729개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,729개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 19
전체 시간: 736
