주요 콘텐츠로 건너뛰기
Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement
필요한 것
  1. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: 1 단계, 이미지 2개 중 1개 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: 1 단계, 이미지 2개 중 2개
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Loosen the belt guard: 2 단계, 이미지 1개 중 1개
    • Use a 1/2" socket and wrench to loosen the two bolts securing the belt guard.
    • The bolts are captive and should not be removed.
  3. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: 3 단계, 이미지 2개 중 1개 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: 3 단계, 이미지 2개 중 2개
    • Remove the belt guard.
  4. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: 4 단계, 이미지 3개 중 1개 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: 4 단계, 이미지 3개 중 2개 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: 4 단계, 이미지 3개 중 3개
    • Use scissors or a blade to cut the drive belt.
    • Remove the drive belt.
  5. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Install a replacement belt: 5 단계, 이미지 1개 중 1개
    • Loop the replacement belt onto the small pulley.
  6. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: 6 단계, 이미지 3개 중 1개 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: 6 단계, 이미지 3개 중 2개 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: 6 단계, 이미지 3개 중 3개
    • Replacing the belt poses a substantial pinching hazard. Wear safety gloves and be mindful where you position your fingers.
    • Guide the belt over the top of the clutch pulley.
    • Loop the belt underneath the pulley axle.
    • Rotate the pulley slowly and guide the built into the groove.
    • Getting the replacement belt back onto the drive pulley requires considerable strength.
결론
작성자
1다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
313,851 평판
안내서 729개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 36
전체 시간: 3,696
