이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
Place the device screen down on a flat surface.
Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
Remove one 11.9mm Phillips #1 screw from the center of the back panel.
Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
Lift the back panel up by a corner and insert a plastic opening tool in the gap.
Slide the tool along the gap around the perimeter of the device while lifting to unlatch the back panel.
Remove the panel by lifting it up and off of the device.
Detach the small black wire connecting the back metal plate to the USB video port by removing the one 8 mm Phillips #2 screw from the back metal plate and turning the screwdriver counterclockwise.
Remove the two 8 mm Phillips #2 screws from the metal button plate by rotating the screwdriver counterclockwise.
Remove the metal button plate from the back metal plate.
Remove the button wires from the support clip by pushing down on the clip.
Detach the button wires from the button board by pulling the button wires away from the board.
Place the button board back in to the device.
Remove the eight (four on each plate) 10.2mm Phillips #2 screws with locking washers from the metal mounting plates by rotating the screwdriver counterclockwise.
Remove the two metal mounting plates.
Remove the sixteen 8 mm Phillips #2 screws with flanges from the horizontal side of the plate by turning the screwdriver counterclockwise.
Remove the ten 8 mm Phillips #2 screws with flanges from the vertical sides of the plate by turning the screwdriver counterclockwise.
Remove the back metal plate by lifting up along one edge , then lifting the plate off and away from the device.
Remove the one 6.8mm Phillips #1 screw by turning the screwdriver counterclockwise.
Remove the four 8mm Phillips #1 screws with flanges by turning the screwdriver counterclockwise.
Remove the five cables connected to the USB board by pinching near the connector and pulling the cables straight out.
Remove USB video port by desoldering at the connection points on the board.
