주요 콘텐츠로 건너뛰기
WarioWare: Twisted! Rumble Motor Replacement
필요한 것
  1. WarioWare: Twisted! Rumble Motor Replacement, Rumble Motor: 1 단계, 이미지 2개 중 1개 WarioWare: Twisted! Rumble Motor Replacement, Rumble Motor: 1 단계, 이미지 2개 중 2개
    • Use a Tri-point Y0 screwdriver to remove the single 3 mm screw located at the back of the game.
    • Remove the cover to expose the control module electronics board underneath.
  2. WarioWare: Twisted! Rumble Motor Replacement: 2 단계, 이미지 3개 중 1개 WarioWare: Twisted! Rumble Motor Replacement: 2 단계, 이미지 3개 중 2개 WarioWare: Twisted! Rumble Motor Replacement: 2 단계, 이미지 3개 중 3개
    • Heat up the soldering iron to approximately 350 degrees Fahrenheit.
    • Remove the rumble motor from the slot.
    • For more information on soldering, refer to How to Solder and Desolder Connections.
    • Apply the tip of the soldering iron to the connection points, causing the red and blue wires to melt and detach.
    • Separate the old rumble motor from the board and set it aside.
    • The soldering iron will be very hot. Do not touch the tip of the iron. It will cause severe burns.
  3. WarioWare: Twisted! Rumble Motor Replacement: 3 단계, 이미지 3개 중 1개 WarioWare: Twisted! Rumble Motor Replacement: 3 단계, 이미지 3개 중 2개 WarioWare: Twisted! Rumble Motor Replacement: 3 단계, 이미지 3개 중 3개
    • Use your hands to remove the black sleeve from the old rumble motor.
    • Set the old rumble motor aside.
    • Use your hands to place the black sleeve onto the new rumble motor you're using.
  4. WarioWare: Twisted! Rumble Motor Replacement: 4 단계, 이미지 3개 중 1개 WarioWare: Twisted! Rumble Motor Replacement: 4 단계, 이미지 3개 중 2개 WarioWare: Twisted! Rumble Motor Replacement: 4 단계, 이미지 3개 중 3개
    • Place the red wire onto the plus (left) side, and the blue wire onto the minus (right) side.
    • To reattach the red and blue wires, carefully bring the tip of the soldering iron into contact with the connection points.
    • The soldering iron will be hot. Do not touch the tip of the iron.
    • Place the new rumble motor back in its slot.
    • Turn off the soldering iron after you finish this step.
  5. WarioWare: Twisted! Rumble Motor Replacement: 5 단계, 이미지 3개 중 1개 WarioWare: Twisted! Rumble Motor Replacement: 5 단계, 이미지 3개 중 2개 WarioWare: Twisted! Rumble Motor Replacement: 5 단계, 이미지 3개 중 3개
    • Put the cover back on the game.
    • Gently push the two sides back together.
  6. WarioWare: Twisted! Rumble Motor Replacement: 6 단계, 이미지 2개 중 1개 WarioWare: Twisted! Rumble Motor Replacement: 6 단계, 이미지 2개 중 2개
    • Use your Tri-point Y0 screwdriver to screw the single 3 mm screw back into place.
    • Test the game to make sure the problem is fixed and you should be ready to play!
결론
I hope this guide solved your problem, and your game should work like new again!
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Brent Thompson
회원 가입일: 06/21/23
181 평판
안내서 1개를 작성함
2가이드 댓글
Nice post and please provide more information. Thanks for sharing.
cunez - 답글
got one of these off eBay for cheap that had no rumble after wanting one for ages! fixing it took about 2 minutes with this guide!
Alex Speegle - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 16
지난 30일: 65
전체 시간: 2,066
