주요 콘텐츠로 건너뛰기
Weller WLC100 Soldering Station NTW56058 TRIAC 16amp switch Replacement
필요한 것
  1. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement, NTW56058 TRIAC 16amp switch: 1 단계, 이미지 1/1
    • Remove the knob from the adjustment dial.
  2. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 2 단계, 이미지 1/1
    • Remove two 8.6 mm Phillips #1 screws from soldering station bottom.
  3. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 3 단계, 이미지 1/1
    • Remove the rubber feet to access the remaining screws.
  4. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 4 단계, 이미지 1/1
    • Remove the remaining two 8.6 mm Phillips #1 screws from soldering station bottom.
  5. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 5 단계, 이미지 1/1
    • Separate the bottom and top half of the soldering station.
  6. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 6 단계, 이미지 1/1
    • Remove the adjustable heat dial board.
  7. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 7 단계, 이미지 1/2 Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 7 단계, 이미지 2/2
    • Orient the new TRIAC switch the same way as the old TRIAC switch is located.
  8. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 8 단계, 이미지 1/2 Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 8 단계, 이미지 2/2
  9. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 9 단계, 이미지 1/1
    • Remove the TRIAC switch when all the solder is removed from the pins.
  10. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 10 단계, 이미지 1/1
    • Insert the new TRIAC switch into the three holes left when you removed the old TRIAC switch.
  11. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 11 단계, 이미지 1/1
    • Solder the new TRIAC switch onto board.
  12. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 12 단계, 이미지 1/1
    • Verify all three pins are soldered in and the solder is not touching the other pins.
  13. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 13 단계, 이미지 1/1
    • Re-install the board into the soldering station.
  14. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 14 단계, 이미지 1/1
    • Push the knob into the hole so that is it protruding out of the other side.
  15. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 15 단계, 이미지 1/1
    • Verify the knob is sticking out of the other side of soldering station.
  16. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 16 단계, 이미지 1/1
    • Replace the dial onto the knob.
  17. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 17 단계, 이미지 1/1
    • Replace the bottom and replace all four screws and rubber feet, reversing steps four though two.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Terence Ryan
회원 가입일: 02/16/21
292 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 8
30일 전: 25
전체 시간: 1,327
