주요 콘텐츠로 건너뛰기
Whirlpool Refrigerator Freezer Door Replacement
필요한 것
  1. Whirlpool Refrigerator Freezer Door Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Freezer Door Replacement, Open the doors: 2 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Freezer Door Replacement, Open the doors: 2 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Freezer Door Replacement, Open the doors: 2 단계, 이미지 3개 중 3개
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the front panel: 3 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the front panel: 3 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the front panel: 3 단계, 이미지 3개 중 3개
    • Remove the screw(s) securing the front panel.
  4. Whirlpool Refrigerator Freezer Door Replacement, Remove the front panel: 4 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Freezer Door Replacement, Remove the front panel: 4 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Freezer Door Replacement, Remove the front panel: 4 단계, 이미지 3개 중 3개
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the door connections: 5 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the door connections: 5 단계, 이미지 2개 중 2개
    • Remove the screw(s) securing the freezer door wiring harness.
    • Remove the screw(s) securing the freezer door water hose.
  6. Whirlpool Refrigerator Freezer Door Replacement, Reposition the wiring harness: 6 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Freezer Door Replacement, Reposition the wiring harness: 6 단계, 이미지 2개 중 2개
    • Pull the wiring harness out of its slot in the chassis to access its connectors.
  7. Whirlpool Refrigerator Freezer Door Replacement, Disconnect the wiring harness: 7 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the wiring harness: 7 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the wiring harness: 7 단계, 이미지 3개 중 3개
    • Disconnect any connectors attached to the door wiring harness.
  8. Whirlpool Refrigerator Freezer Door Replacement: 8 단계, 이미지 1개 중 1개
    • Place a clean cloth under the water hose before continuing.
  9. Whirlpool Refrigerator Freezer Door Replacement: 9 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Freezer Door Replacement: 9 단계, 이미지 2개 중 2개
    • Pull the plastic clip off the freezer door water hose.
  10. Whirlpool Refrigerator Freezer Door Replacement, Disconnect the water hose: 10 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the water hose: 10 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the water hose: 10 단계, 이미지 3개 중 3개
    • Use one hand to compress the blue plastic ring into the green section of the hose.
    • Use the other hand to pull the water tube out of its slot.
  11. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the freezer door: 11 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the freezer door: 11 단계, 이미지 2개 중 2개
    • Depending on your device, you may have a plastic cover on the hinge. Remove it before continuing.
    • Hold the door while performing the next two steps to avoid the door from accidentally falling.
    • Remove the screw(s) securing the freezer door.
    • Some devices may have screws solely for alignment. You don't need to remove these.
  12. Whirlpool Refrigerator Freezer Door Replacement, Remove the door hinge: 12 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Freezer Door Replacement, Remove the door hinge: 12 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Freezer Door Replacement, Remove the door hinge: 12 단계, 이미지 3개 중 3개
    • Pull the door hinge straight up to separate its alignment pins from the chassis.
    • Remove the door hinge.
  13. Whirlpool Refrigerator Freezer Door Replacement, Reposition the cables: 13 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Freezer Door Replacement, Reposition the cables: 13 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Freezer Door Replacement, Reposition the cables: 13 단계, 이미지 3개 중 3개
    • Pull the freezer door straight up to disconnect it from the chassis.
    • Thread the cables through their slot in the chassis.
    • You may need to thread them individually.
  14. Whirlpool Refrigerator Freezer Door Replacement, Remove the door: 14 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Freezer Door Replacement, Remove the door: 14 단계, 이미지 2개 중 2개
    • You're now left with the freezer door.
결론
Repair didn’t go as planned? Ask our Answers community for help.
작성자
1다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,927 평판
안내서 89개를 작성함
Global Fixers Global Fixers 회원
Community
45 회원들
안내서 702개를 작성함
댓글 한 개
There is a pending class action suit about this defect: https://chimicles.com/whirlpool-refriger...
Barbara Hoover - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 60
전체 시간: 1,978
