주요 콘텐츠로 건너뛰기
Why You Should Clean and Maintain Your Automatic Coffeemaker
필요한 것
    • Remove all loose attachments such as the water tank, drip tray, and coffee beans. Open the machine using this guide.
    • Inspect the water hoses and internal components for any signs of contamination.
    • The hoses don’t always need to be replaced. Often, cleaning with a thin brush, detergent, and hot water is sufficient.
    • Remove the screw on the cover. Remove the cover.
    • Unscrew the brewing unit.
    • Carefully remove the brewing unit for inspection and cleaning.
    • Detach the drainage valve to check for internal contamination.
    • This guide shows, how to overhaul the drainage valve.
    • Pre-clean parts before placing them in an ultrasonic bath for deep cleaning.
    • If you don’t have access to an ultrasonic bath, clean all parts thoroughly with hot water and detergent. Avoid using a dishwasher.
    • Install new or cleaned hoses and replace any worn-out seals.
    • Thorough cleaning of the interior and exterior is necessary.
    • The coffee spout tends to become contaminated with coffee grease. If you want to remove it, you have to remove the spout, which can be quite time-consuming.
    • After cleaning and replacing necessary parts, reassemble the machine.
    • Run a cleaning and descaling cycle before brewing coffee again.
결론
Repair didn't go as planned? Try some basic troubleshooting, or ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
eCuration
회원 가입일: 05/19/17
450,149 평판
안내서 252개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,639개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 567
전체 시간: 1,416
