주요 콘텐츠로 건너뛰기
Womier K66 Mechanical Keyboard Switch Replacement
필요한 것
  1. Womier K66 Mechanical Keyboard Switch Replacement, Switch: 1 단계, 이미지 3개 중 1개 Womier K66 Mechanical Keyboard Switch Replacement, Switch: 1 단계, 이미지 3개 중 2개 Womier K66 Mechanical Keyboard Switch Replacement, Switch: 1 단계, 이미지 3개 중 3개
    • Remove the keycaps from the keyboard using the keycap remover.
  2. Womier K66 Mechanical Keyboard Switch Replacement: 2 단계, 이미지 3개 중 1개 Womier K66 Mechanical Keyboard Switch Replacement: 2 단계, 이미지 3개 중 2개 Womier K66 Mechanical Keyboard Switch Replacement: 2 단계, 이미지 3개 중 3개
    • Flip the keyboard over so the backside is facing up.
    • Use the Phillips #0 screwdriver to remove the fourteen 1.52 mm screws.
    • Remove the back plate of the keyboard.
  3. Womier K66 Mechanical Keyboard Switch Replacement: 3 단계, 이미지 3개 중 1개 Womier K66 Mechanical Keyboard Switch Replacement: 3 단계, 이미지 3개 중 2개 Womier K66 Mechanical Keyboard Switch Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    • If you're unfamiliar with solder or need a refresher, review the How to Solder and Desolder guide.
    • Set your soldering iron to 400 °C.
    • Apply the soldering iron to the solder joints and remove the solder with the desoldering pump.
    • Be careful when soldering as the iron is very hot.
  4. Womier K66 Mechanical Keyboard Switch Replacement: 4 단계, 이미지 3개 중 1개 Womier K66 Mechanical Keyboard Switch Replacement: 4 단계, 이미지 3개 중 2개 Womier K66 Mechanical Keyboard Switch Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the key switch from the board using the key switch puller.
  5. Womier K66 Mechanical Keyboard Switch Replacement: 5 단계, 이미지 3개 중 1개 Womier K66 Mechanical Keyboard Switch Replacement: 5 단계, 이미지 3개 중 2개 Womier K66 Mechanical Keyboard Switch Replacement: 5 단계, 이미지 3개 중 3개
    • Place your new switch onto the board.
    • In this case we used a Gateron Linear switch but this could be any variety of switches.
  6. Womier K66 Mechanical Keyboard Switch Replacement: 6 단계, 이미지 3개 중 1개 Womier K66 Mechanical Keyboard Switch Replacement: 6 단계, 이미지 3개 중 2개 Womier K66 Mechanical Keyboard Switch Replacement: 6 단계, 이미지 3개 중 3개
    • Apply new solder to the soldering joints of the replacement switch.
결론
작성자
4다른 기여자 명과 함께
Minh-Tam Nguyen
회원 가입일: 11/03/22
133 평판
안내서 1개를 작성함
York University, Team B-7, Allen Fall 2022 York University, Team B-7, Allen Fall 2022 회원
YORK-ALLEN-F22SBG7
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 19
전체 시간: 800
