주요 콘텐츠로 건너뛰기
X-Treme Tablet Generation 2 Battery Replacement
필요한 것
  1. X-Treme Tablet Generation 2 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Start on the edge of the top corner and use a spudger opening tool to carefully pry the back cover off of the main body.
    • Continue prying around the device, being careful to not dislodge the power button.
  2. X-Treme Tablet Generation 2 Battery Replacement: 2 단계, 이미지 1/3 X-Treme Tablet Generation 2 Battery Replacement: 2 단계, 이미지 2/3 X-Treme Tablet Generation 2 Battery Replacement: 2 단계, 이미지 3/3
    • Pull the cloth tape from the battery to free the body of the battery.
    • Use a solder vacuum and soldering iron to release the red, and then the black, wire from the motherboard.
  3. X-Treme Tablet Generation 2 Battery Replacement: 3 단계, 이미지 1/2 X-Treme Tablet Generation 2 Battery Replacement: 3 단계, 이미지 2/2
    • Remove the battery from the device.
    • Insert the new 3.7 V Li-Polymer battery into the device.
    • Use the soldering iron to solder the red, and then the black, wire back to motherboard.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mike Longshore
회원 가입일: 01/28/15
125 평판
안내서 1개 작성함
Pasco Hernando, Team 5-4, Prince Winter 2015 Pasco Hernando, Team 5-4, Prince Winter 2015 회원
PHSC-PRINCE-W15S5G4
6 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 1,078
