주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox 360 Bottom Vent Replacement
필요한 것
  1. Xbox 360 Bottom Vent Replacement, Bottom Vent: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Xbox 360 Opening Tool
    • Stand the console vertically with the bottom edge facing up.
    • Throughout the following opening procedure, the finger of an Xbox 360 opening tool can be used in place of a spudger.
    • Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
    • Pry the front edge of the bottom vent away from the faceplate.
  2. Xbox 360 Bottom Vent Replacement: 2 단계, 이미지 3개 중 1개 Xbox 360 Bottom Vent Replacement: 2 단계, 이미지 3개 중 2개 Xbox 360 Bottom Vent Replacement: 2 단계, 이미지 3개 중 3개
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the bottom vent. Their locations are highlighted in red.
    • You will insert the tool into the holes molded into the white plastic side case pieces.
  3. Xbox 360 Bottom Vent Replacement: 3 단계, 이미지 2개 중 1개 Xbox 360 Bottom Vent Replacement: 3 단계, 이미지 2개 중 2개
    • To release the clips, work from the front edge of the bottom vent.
    • While slightly lifting the front edge of the bottom vent, use the tip of a spudger to push the clips closest to the front of the bottom vent towards the inside of the console.
  4. Xbox 360 Bottom Vent Replacement: 4 단계, 이미지 2개 중 1개 Xbox 360 Bottom Vent Replacement: 4 단계, 이미지 2개 중 2개
    • Repeat the same process to release the two center clips on the bottom vent.
  5. Xbox 360 Bottom Vent Replacement: 5 단계, 이미지 2개 중 1개 Xbox 360 Bottom Vent Replacement: 5 단계, 이미지 2개 중 2개
    • Use the tip of your spudger to release the clips on the bottom vent nearest the back of the Xbox.
  6. Xbox 360 Bottom Vent Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the bottom vent from the 360.
결론
다른 69명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Walter Galan
707,380 평판
안내서 1,203개를 작성함
1가이드 댓글
cool thanks for the tip
exavier smith - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 44
지난 30일: 212
전체 시간: 30,324
