주요 콘텐츠로 건너뛰기
Xbox 360 Bottom Vent Replacement
필요한 것
  1. Xbox 360 Bottom Vent Replacement, Bottom Vent: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Xbox 360 Opening Tool
    • Stand the console vertically with the bottom edge facing up.
    • Throughout the following opening procedure, the finger of an Xbox 360 opening tool can be used in place of a spudger.
    • Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
    • Pry the front edge of the bottom vent away from the faceplate.
  2. Xbox 360 Bottom Vent Replacement: 2 단계, 이미지 3개 중 1개 Xbox 360 Bottom Vent Replacement: 2 단계, 이미지 3개 중 2개 Xbox 360 Bottom Vent Replacement: 2 단계, 이미지 3개 중 3개
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the bottom vent. Their locations are highlighted in red.
    • You will insert the tool into the holes molded into the white plastic side case pieces.
  3. Xbox 360 Bottom Vent Replacement: 3 단계, 이미지 2개 중 1개 Xbox 360 Bottom Vent Replacement: 3 단계, 이미지 2개 중 2개
    • To release the clips, work from the front edge of the bottom vent.
    • While slightly lifting the front edge of the bottom vent, use the tip of a spudger to push the clips closest to the front of the bottom vent towards the inside of the console.
  4. Xbox 360 Bottom Vent Replacement: 4 단계, 이미지 2개 중 1개 Xbox 360 Bottom Vent Replacement: 4 단계, 이미지 2개 중 2개
    • Repeat the same process to release the two center clips on the bottom vent.
  5. Xbox 360 Bottom Vent Replacement: 5 단계, 이미지 2개 중 1개 Xbox 360 Bottom Vent Replacement: 5 단계, 이미지 2개 중 2개
    • Use the tip of your spudger to release the clips on the bottom vent nearest the back of the Xbox.
  6. Xbox 360 Bottom Vent Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the bottom vent from the 360.
결론
다른 68명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Walter Galan
701,099 평판
안내서 1,203개를 작성함
댓글 한 개
cool thanks for the tip
exavier smith - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 31
지난 30일: 73
전체 시간: 28,927
