주요 콘텐츠로 건너뛰기
Xbox 360 Motherboard Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Xbox 360 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 Xbox 360 Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 Xbox 360 Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Use the flat end of a spudger to release the clips securing the RF module shield along the top and the left edge of the RF module.
    • It may be easier to use your fingernail to release the clips from the RF module.
    • Remove the RF module shield from the console.
  2. Xbox 360 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove three 5.6 mm T8 Torx screws securing the RF module to the metal chassis.
  3. Xbox 360 Motherboard Replacement: 3 단계, 이미지 1/2 Xbox 360 Motherboard Replacement: 3 단계, 이미지 2/2
    • Grasp the RF module and lift it straight up to disconnect it from its socket on the motherboard.
    • Remove the RF module from the console.
  4. Xbox 360 Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the following screws securing the motherboard to the metal casing:
    • Nine gold 11 mm T10 Torx screws.
    • Eight black 5.6 mm T8 Torx screws.
    • If you are reassembling your Xbox 360 after installing the Red Ring of Death Fix Kit, the eight T8 Torx screws circled in orange are not reused.
  5. Xbox 360 Motherboard Replacement: 5 단계, 이미지 1/2 Xbox 360 Motherboard Replacement: 5 단계, 이미지 2/2
    • Turn the Xbox over, being careful not to let the motherboard fall out of the chassis.
    • Lift the motherboard assembly from its front edge.
    • Be careful not to damage the sockets as you rotate the motherboard away from the metal casing.
    • Remove the motherboard assembly from the metal casing.
결론
Walter Galan
694,692 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,072
