주요 콘텐츠로 건너뛰기
Xbox 360 Wireless Controller 3D Analog Sensor Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Battery: 1 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Rear Case: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
    Any recommendation on which set of Security Torx tools to use? I've already purchased 2 kits, one of those being sold as "Xbox controller tools" but the diameter of the head does not fit the hole on the controller and that's critical for the 2 screws on the bottom. The tools must obviously be thinner in diameter and long enough to get there.
    Arnie - 답글
    How to open an XBOX 360 controller without a special screwdriver. http://www.instructables.com/id/How-to-o... Works perfectly.
    Louis - 답글
    A lot of thanks for your comment. It's very usefull
    Echedey -
    I picked up a handy torx key set from Auto Zone. Was about $10, no lose driver bits. has both sizes you need to repair the controller and the console. Here's the link:
    http://www.autozone.com/autozone/accesso...
    FierDancr - 답글
    It doesn't really matter which set of bits you by or what brand makes them, Torx bits (and the security versions of them) are generic & come in standardized sizes. You do not need a special "xbox" tool kit, you just need a size 8 torx security bit, no matter what brand makes the bit/kit. Those types of "specialty kits" are usually just collections of generic bits that you can buy at a hardware store in a regular bit set. The difference is that a general bit set will have bits for screws that a specific item doesn't have in it, whereas a specialty kit will only include bits for the types & sizes of fasteners used in the specified item.
    BTW, with the smaller sizes of torx security bits you can try breaking off the little post in the middle with needlenose pliers or something else that can fit in the there. Even if the post doesn't break off cleanly, it's usually short enough to fit a regular (non security) torx bit in the slot.
    Nerfbomb - 답글
  4. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 4 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Spudger
    $2.99
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  5. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 5 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 5 단계, 이미지 2개 중 2개
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  6. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 6 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 6 단계, 이미지 2개 중 2개
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
    The RB / LB bar will fall away easily as you handle the upper case and logic board; just be prepared for it.
    knoxco - 답글
  7. Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Vibration Motors: 7 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Vibration Motors: 7 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
  8. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 8 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
    The opposite was true for the controller I just opened. It was the left motor counterweight (as you hold the controller normally) which had more weight. Perhaps it doesn't matter which goes where?
    Bob S - 답글
    For anyone reading this in the future, it does matter. The way you had them originally is the correct way.
    Yado Nada -
  9. Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Logic Board: 9 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Logic Board: 9 단계, 이미지 2개 중 2개
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
    What if you're having difficulty taking the logic board out?
    Xander Uchida - 답글
    In my experience with my controller, the logic board lifts out very easily, there are no tabs or fasteners holding it in.
    So, if you're having difficulty taking the logic board out, call a friend with average hand dexterity & motor skills to do it for you.
    Nerfbomb - 답글
    If the controller is a bit old, the center plastic screw holder might have swollen and will need a little stenght to release the logic board.
    RoFixedIt - 답글
  10. Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Triggers: 10 단계, 이미지 3개 중 1개 Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Triggers: 10 단계, 이미지 3개 중 2개 Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Triggers: 10 단계, 이미지 3개 중 3개
    • Using your thumb and forefinger, push the left trigger toward the right side of the controller. Simultaneously push the trigger control arm in the opposite direction.
    • The trigger has a peg that fits into a slot in the trigger arm. Be sure to push far enough so that the peg clears the slot.
    • Push the trigger arm downward.
  11. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 11 단계, 이미지 3개 중 1개 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 11 단계, 이미지 3개 중 2개 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 11 단계, 이미지 3개 중 3개
    • Insert the edge of a spudger in between the trigger and the trigger assembly near the left edge. Pry the housing away from the catch on the trigger.
    • Using the previously described technique, pry the housing on the right edge away from the trigger.
    • Rotate the trigger away from the logic board, past its housing.
  12. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 12 단계, 이미지 3개 중 1개 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 12 단계, 이미지 3개 중 2개 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 12 단계, 이미지 3개 중 3개
    • Using a spudger, pry the trigger spring off its peg on the trigger housing.
    • Pull the trigger spring out of the trigger.
  13. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 13 단계, 이미지 3개 중 1개 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 13 단계, 이미지 3개 중 2개 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: 13 단계, 이미지 3개 중 3개
    • Slide the trigger toward the right side of the logic board, and rotate it clockwise.
    • Remove the right trigger from the logic board.
    • To remove the left trigger from the logic board, follow the procedure previously described for the right trigger.
    This is a removal guide not a replacement guide. I need steps to putting the trigger back in now.
    Paul de Boer - 답글
    My trigger works by moving in and out but it is constantly either working or constantly not, when i press the home screen it switches between the two……help please
    Daunte Mooney - 답글
    • To remove the trigger control, only one has to be removed as it is over the analog sensor (left side).
    • Optional: It is easier to remove both, so as to avoid burning or melting the plastic while working.
    • The part should easily slide out once the solder is properly removed. If not, go back and check for solder left in the joints.
    • Heat and suck up the solder.
    • Remove analog sensor and place new part.
    • Hold part in place and make a quick solder to hold it up in place.
    • Now solder all joints and follow in reverse.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
_Z_
회원 가입일: 03/18/12
9,695 평판
안내서 2개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,697개를 작성함
댓글 한 개
this guide will be finished as soon as i have time.
_Z_ - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 2,650
