주요 콘텐츠로 건너뛰기
Xbox 360 Wireless Controller Battery Replacement
필요한 것
  1. Xbox 360 Wireless Controller Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
결론
다른 42명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Brett Hartt
회원 가입일: 04/12/10
131,238 평판
안내서 143개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,648개를 작성함
5가이드 댓글
Oh wow! Thanks so much! I don't know what I would do without this guide!!
ForumHermit - 답글
This guide helped me so much! I didn't know how to replace the battery.
Kaeden Irvine - 답글
I just got a rechargable battery pack but the springs are still connected to the controller. How do i safely remove the springs without damaging or taking apart the controller?
Miranda Copus - 답글
My batterys spilled batteryfluid , is it saveable the controller or do i need a new one
GudS. - 답글
Use vinegar and a cue tip to clean the alkaline off. Then clean the vinegar off with Isopropyl alcohol. Sandpaper, or wire brush if really bad
Burned -
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 159
지난 30일: 379
전체 시간: 44,355
