주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox One Front Panel Board Replacement
필요한 것
  1. Xbox One Front Panel Board Replacement, Upper Case: 1 단계, 이미지 1개 중 1개
  2. Xbox One Front Panel Board Replacement: 2 단계, 이미지 2개 중 1개 Xbox One Front Panel Board Replacement: 2 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry up and remove the plastic vent that surrounds the side USB port.
    • The vent is fairly flexible, and held in place with weak plastic clips—start prying from the back and peel it out.
  3. Xbox One Front Panel Board Replacement: 3 단계, 이미지 2개 중 1개 Xbox One Front Panel Board Replacement: 3 단계, 이미지 2개 중 2개
    • There is a small plastic tab that reinforces the front corner of the Xbox.
    • Slide the tab straight back and remove it.
  4. Xbox One Front Panel Board Replacement: 4 단계, 이미지 2개 중 1개 Xbox One Front Panel Board Replacement: 4 단계, 이미지 2개 중 2개
    • Insert the flat end of a spudger between the upper and lower case where they meet at the rear of the side vent opening.
    • There is a strong plastic clip connecting the two case halves (the first of many), so you'll need to use quite a bit of force.
    • Leave the spudger in place until you open the case completely. The clips are very springy and may cause the case to snap shut while you're working.
  5. Xbox One Front Panel Board Replacement: 5 단계, 이미지 2개 중 1개 Xbox One Front Panel Board Replacement: 5 단계, 이미지 2개 중 2개
    • The interface between the upper and lower cases is secured by several clips along the rear and remaining side of the Xbox.
    • Insert a plastic opening tool between the upper and lower case to separate the clip over the rear vent.
  6. Xbox One Front Panel Board Replacement: 6 단계, 이미지 2개 중 1개 Xbox One Front Panel Board Replacement: 6 단계, 이미지 2개 중 2개
    • Keep moving along the rear of the Xbox, prying up clips.
    • Make sure the spudger stays in its blocking position—even if the case opens up enough for the spudger to fall out, the remaining clips are springy and may pull the case completely shut. Keep the spudger in the gap to protect your progress.
  7. Xbox One Front Panel Board Replacement: 7 단계, 이미지 2개 중 1개 Xbox One Front Panel Board Replacement: 7 단계, 이미지 2개 중 2개
    • Keep popping clips. It may help to slide the plastic opening tool across the clips.
    • By the time you get to the far edge of the rear case, the top case should be ready to come off. If not, run your plastic opening tool around the corner and pop the clips along the side without the USB port.
  8. Xbox One Front Panel Board Replacement: 8 단계, 이미지 3개 중 1개 Xbox One Front Panel Board Replacement: 8 단계, 이미지 3개 중 2개 Xbox One Front Panel Board Replacement: 8 단계, 이미지 3개 중 3개
    • Starting with the spudger you left in the crack, pry the upper case up to free the last few clips.
    • Use a plastic opening tool to pop any straggler clips that weren't freed.
    • Do not try to remove the upper case yet, as it is still connected by the front panel button cable.
    • Lift the upper case slightly and shift it to give access to the front panel board.
  9. Xbox One Front Panel Board Replacement: 9 단계, 이미지 3개 중 1개 Xbox One Front Panel Board Replacement: 9 단계, 이미지 3개 중 2개 Xbox One Front Panel Board Replacement: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • The front button cable has a unique ZIF connector—pay attention to the next few steps to safely disconnect it.
    • Use tweezers to lift the blue plastic retaining loop over the white connector on the board.
    • Use the tip of a spudger to push the connector's locking tab toward the cable to unlatch it.
  10. Xbox One Front Panel Board Replacement: 10 단계, 이미지 2개 중 1개 Xbox One Front Panel Board Replacement: 10 단계, 이미지 2개 중 2개
    • Use tweezers to pull the cable straight out of the connector on the board.
    • Remove the upper case.
  11. Xbox One Front Panel Board Replacement, Reassembly Instructions: 11 단계, 이미지 3개 중 1개 Xbox One Front Panel Board Replacement, Reassembly Instructions: 11 단계, 이미지 3개 중 2개 Xbox One Front Panel Board Replacement, Reassembly Instructions: 11 단계, 이미지 3개 중 3개
    • The next 4 steps are directions for reassembly. Skip them to continue with disassembly.
    • Use the flat end of a spudger to free the clips securing the front panel to the upper case.
    • Remove the front panel from the rest of the upper case.
  12. Xbox One Front Panel Board Replacement: 12 단계, 이미지 3개 중 1개 Xbox One Front Panel Board Replacement: 12 단계, 이미지 3개 중 2개 Xbox One Front Panel Board Replacement: 12 단계, 이미지 3개 중 3개
    • Replace the top part of the upper case.
    • Line up the clips and press firmly to re-seat them around the perimeter.
  13. Xbox One Front Panel Board Replacement: 13 단계, 이미지 3개 중 1개 Xbox One Front Panel Board Replacement: 13 단계, 이미지 3개 중 2개 Xbox One Front Panel Board Replacement: 13 단계, 이미지 3개 중 3개
    • Support the front panel near the front of the Xbox.
    • Use tweezers to replace the front button cable in its ZIF socket.
    • Use the flat end of a spudger to push the ZIF lock to the left to secure the cable.
  14. Xbox One Front Panel Board Replacement: 14 단계, 이미지 3개 중 1개 Xbox One Front Panel Board Replacement: 14 단계, 이미지 3개 중 2개 Xbox One Front Panel Board Replacement: 14 단계, 이미지 3개 중 3개
    • The lower edge of the front panel has plastic hooks that interlock with plastic hooks on the front edge of the lower case.
    • With the front panel at a 45 degree angle, interlock its plastic hooks with those in the lower case.
    • Push the top of the front panel into the Xbox, like closing a mailbox. Press firmly so that the clips securing the front panel to the upper case lock securely.
  15. Xbox One Front Panel Board Replacement, Upper Metal Case: 15 단계, 이미지 3개 중 1개 Xbox One Front Panel Board Replacement, Upper Metal Case: 15 단계, 이미지 3개 중 2개 Xbox One Front Panel Board Replacement, Upper Metal Case: 15 단계, 이미지 3개 중 3개
    • Gently pull up on the speaker cable connector to disconnect it from the front panel board.
    • Be careful to pull up on the cable's connector and not the connector on the board. It's pretty flimsy and you might accidentally pull it off the board entirely.
    • Use the flat end of a spudger to disconnect the antenna cable from the front panel board.
  16. Xbox One Front Panel Board Replacement: 16 단계, 이미지 3개 중 1개 Xbox One Front Panel Board Replacement: 16 단계, 이미지 3개 중 2개 Xbox One Front Panel Board Replacement: 16 단계, 이미지 3개 중 3개
    • Remove the two 9.5 mm T8 Torx screws from the WI-Fi board.
    • Lift the Wi-Fi board straight up from its socket in the upper metal case.
    • Leaving the Wi-Fi board antenna cable in place, move the Wi-Fi board aside, exposing the screw labeled "C3" that was beneath it.
  17. Xbox One Front Panel Board Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the eight 65 mm Torx T10 screws from the top of the upper metal case.
  18. Xbox One Front Panel Board Replacement: 18 단계, 이미지 2개 중 1개 Xbox One Front Panel Board Replacement: 18 단계, 이미지 2개 중 2개
    • Lift—but do not remove—the upper metal case.
    • The Wi-Fi board interconnect cable connects the upper metal case to the motherboard.
  19. Xbox One Front Panel Board Replacement: 19 단계, 이미지 2개 중 1개 Xbox One Front Panel Board Replacement: 19 단계, 이미지 2개 중 2개
    • Disconnect the Wi-Fi board interconnect cable from the motherboard.
    • Remove the upper metal case.
  20. Xbox One Front Panel Board Replacement, Hard Drive Assembly: 20 단계, 이미지 3개 중 1개 Xbox One Front Panel Board Replacement, Hard Drive Assembly: 20 단계, 이미지 3개 중 2개 Xbox One Front Panel Board Replacement, Hard Drive Assembly: 20 단계, 이미지 3개 중 3개
    • Disconnect the hard drive SATA power and data cables from the motherboard.
  21. Xbox One Front Panel Board Replacement: 21 단계, 이미지 1개 중 1개
    • Lift and remove the hard drive tray from the Xbox.
  22. Xbox One Front Panel Board Replacement, Optical Drive Assembly: 22 단계, 이미지 3개 중 1개 Xbox One Front Panel Board Replacement, Optical Drive Assembly: 22 단계, 이미지 3개 중 2개 Xbox One Front Panel Board Replacement, Optical Drive Assembly: 22 단계, 이미지 3개 중 3개
    • Disconnect the optical drive power and SATA data cables from the motherboard.
  23. Xbox One Front Panel Board Replacement: 23 단계, 이미지 1개 중 1개
    • Remove the optical drive assembly from the Xbox.
  24. Xbox One Front Panel Board Replacement, Front Panel Board: 24 단계, 이미지 1개 중 1개
    • Lift the motherboard assembly out of the lower case.
  25. Xbox One Front Panel Board Replacement: 25 단계, 이미지 1개 중 1개
    • Remove the three 9.5 mm T9 Torx screws securing the front panel board.
  26. Xbox One Front Panel Board Replacement: 26 단계, 이미지 1개 중 1개
    • Disconnect the front panel board from its socket in the front of the motherboard.
결론
다른 26명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andrew Optimus Goldheart
회원 가입일: 10/17/09
514,901 평판
안내서 407개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 25,713개를 작성함
4가이드 댓글
Hi would you know where I could get that panel from that reienforces my consol
Nelson okanee - 답글 공유
Also my button won't work to sync a new controller what part do I get to fix that
I did all that. Put it back together, now i push my power button and it only lights up for a second then dies. The power box and source are good. What did i do wrong?
Chris Chapman - 답글 공유
My Xbox turns on and immediately turns back off pls help
gavin moyer - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 55
지난 30일: 303
전체 시간: 73,658
