주요 콘텐츠로 건너뛰기
Xbox One S All Digital Edition Power Supply Replacement
필요한 것
  1. Xbox One S All Digital Edition Power Supply Replacement, Plastic Enclosure: 1 단계, 이미지 1/3 Xbox One S All Digital Edition Power Supply Replacement, Plastic Enclosure: 1 단계, 이미지 2/3 Xbox One S All Digital Edition Power Supply Replacement, Plastic Enclosure: 1 단계, 이미지 3/3
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Power Supply Replacement: 2 단계, 이미지 1/2 Xbox One S All Digital Edition Power Supply Replacement: 2 단계, 이미지 2/2
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Power Supply Replacement: 3 단계, 이미지 1/2 Xbox One S All Digital Edition Power Supply Replacement: 3 단계, 이미지 2/2
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Power Supply Replacement: 4 단계, 이미지 1/1
    • Flip the metal enclosure so that the fan cover is on top.
  5. Xbox One S All Digital Edition Power Supply Replacement, Top Metal Shield: 5 단계, 이미지 1/2 Xbox One S All Digital Edition Power Supply Replacement, Top Metal Shield: 5 단계, 이미지 2/2
    • Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
  6. Xbox One S All Digital Edition Power Supply Replacement: 6 단계, 이미지 1/3 Xbox One S All Digital Edition Power Supply Replacement: 6 단계, 이미지 2/3 Xbox One S All Digital Edition Power Supply Replacement: 6 단계, 이미지 3/3
    • Carefully slide the top metal case off the frame.
    • This may require shifting the case side to side as you slide up.
  7. Xbox One S All Digital Edition Power Supply Replacement, Wifi Card: 7 단계, 이미지 1/2 Xbox One S All Digital Edition Power Supply Replacement, Wifi Card: 7 단계, 이미지 2/2
    • Remove the three 15 mm screws with the Torx T8 Security Bit Screwdriver.
    • The top of the metal chassis has been removed in the picture, but is not necessary for the replacement.
  8. Xbox One S All Digital Edition Power Supply Replacement: 8 단계, 이미지 1/1
    • Carefully remove the WiFi Card from the metal chassis.
  9. Xbox One S All Digital Edition Power Supply Replacement, IR Blaster: 9 단계, 이미지 1/2 Xbox One S All Digital Edition Power Supply Replacement, IR Blaster: 9 단계, 이미지 2/2
    • Remove the four 15mm screws attaching the IR Blaster to the metal chassis with the Torx T8 Security screwdriver.
  10. Xbox One S All Digital Edition Power Supply Replacement: 10 단계, 이미지 1/2 Xbox One S All Digital Edition Power Supply Replacement: 10 단계, 이미지 2/2
    • Carefully remove the IR Blaster from the metal chassis.
    • The connector is very fragile. Make sure you pull the board away from the case and not sideways.
  11. Xbox One S All Digital Edition Power Supply Replacement, Bottom Metal Shield: 11 단계, 이미지 1/2 Xbox One S All Digital Edition Power Supply Replacement, Bottom Metal Shield: 11 단계, 이미지 2/2
    • Remove the eight 10mm screws from the bottom of the metal casing using the Torx T9 screwdriver.
    • Remove the four 15mm screws from the bottom of the heatsink fastener using the Torx T8 screwdriver.
  12. Xbox One S All Digital Edition Power Supply Replacement: 12 단계, 이미지 1/3 Xbox One S All Digital Edition Power Supply Replacement: 12 단계, 이미지 2/3 Xbox One S All Digital Edition Power Supply Replacement: 12 단계, 이미지 3/3
    • Remove the two plastic pieces from the motherboard.
  13. Xbox One S All Digital Edition Power Supply Replacement: 13 단계, 이미지 1/3 Xbox One S All Digital Edition Power Supply Replacement: 13 단계, 이미지 2/3 Xbox One S All Digital Edition Power Supply Replacement: 13 단계, 이미지 3/3
    • Lift the motherboard up from the metal chassis.
    • The motherboard should easily separate from the metal chassis.
  14. Xbox One S All Digital Edition Power Supply Replacement, Power Supply: 14 단계, 이미지 1/3 Xbox One S All Digital Edition Power Supply Replacement, Power Supply: 14 단계, 이미지 2/3 Xbox One S All Digital Edition Power Supply Replacement, Power Supply: 14 단계, 이미지 3/3
    • Gently lift the hard drive to free up some space around the power supply.
  15. Xbox One S All Digital Edition Power Supply Replacement: 15 단계, 이미지 1/2 Xbox One S All Digital Edition Power Supply Replacement: 15 단계, 이미지 2/2
    • Lift the power supply up and away from the motherboard.
  16. Xbox One S All Digital Edition Power Supply Replacement: 16 단계, 이미지 1/2 Xbox One S All Digital Edition Power Supply Replacement: 16 단계, 이미지 2/2
    • Disconnect the six pin connector from the motherboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Jules Hajjar
회원 가입일: 10/10/19
1,573 평판
안내서 8개 작성하였습니다
Cal Poly, Team S12-G6, Regan Fall 2019 Cal Poly, Team S12-G6, Regan Fall 2019 회원
CPSU-REGAN-F19S12G6
4 회원들
안내서 26개 작성하였습니다
댓글 3개
I replaced the power supply and my Xbox still isn't turning on. I used a power supply I got from this website. Please help
William Oliver - 답글
Another issue could be the power button on the front power board. If possible, you could try to replace that as well.
Jules Hajjar -
replace the PSU and still boots up and shuts off
imafuxer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 35
30일 전: 176
전체 시간: 7,201
