주요 콘텐츠로 건너뛰기
Xbox One S Heatsink/Fan Replacement
필요한 것
  1. Xbox One S Heatsink/Fan Replacement, Case: 1 단계, 이미지 1/1
    • Flip the Xbox One S so that the bottom of the case is facing upward.
  2. Xbox One S Heatsink/Fan Replacement: 2 단계, 이미지 1/1
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
    Be careful not to damage the pairing button on this part
    David - 답글
    Important!!
    You've to start from the back corner where is the information label, because there is a main clip behind a warranty sticker
    Cristian Ramirez - 답글
    They should add this to the guide! I didnt know that, and did some minor damage to the bottom piece where that main clip is.
    I dont mind because it's my own Xbox, but what if it belonged to a customer?
    Charles Jackson -
    💯% same opinion!
    profnussecke42o -
    This was hard! I tried using plastic pry tools, but they did not work. A metal tool did, but make sure to watch a video or two, to see what you actually are dealing with. After the videos it went quite smoothly.
    Peterdk - 답글
    I legitimately cannot open the case where the warranty sticker is, ive tried everything, im resorting to a fork to try and open this
    Sohail ツShah - 답글
  3. Xbox One S Heatsink/Fan Replacement: 3 단계, 이미지 1/1
    • Once all of the clips are opened, remove the bottom part of the case.
  4. Xbox One S Heatsink/Fan Replacement: 4 단계, 이미지 1/2 Xbox One S Heatsink/Fan Replacement: 4 단계, 이미지 2/2
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
    My F3 isn't coming out. The screwdriver isn't sitting tight like it is for the other ones. Any idea on how to fix that?
    ben mccord - 답글
  5. Xbox One S Heatsink/Fan Replacement: 5 단계, 이미지 1/2 Xbox One S Heatsink/Fan Replacement: 5 단계, 이미지 2/2
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield
    Essential tip: be sure to slide the metal housing backward, away from the from of the case as pictured above, rather than upward. If not, you can easily break off the teeny momentary switches on the IR blaster board!
    Mark Ross - 답글
    “appropriate method is not descriptive like Mr. Ross’s comment. The original poster should edit the description to ensure people do in fact remove the box from the case appropriately. I would also add arrows to the picture.
    Ryan A - 답글
    ____________⬆️
    ↖️Yes! I see it the same way!↗️
    ⬅️Arrows are always a good thing!➡️
    ↙️Can't do anything wrong with them! ↘️
    ____________⬇️
    profnussecke42o -
    I didn't realize that metal ribbon was connecting the case to the console and I yanked it w out realizing it was there. How o I get a replacement?
    Jerianna Mike - 답글
  6. Xbox One S Heatsink/Fan Replacement, Hard Drive Assembly: 6 단계, 이미지 1/2 Xbox One S Heatsink/Fan Replacement, Hard Drive Assembly: 6 단계, 이미지 2/2
    • To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C5, from the backside of the Xbox One S.
    • Some models may require C4 and C5.
    • This will allow the plastic casing surrounding the hard drive to become detached from the rest of the console.
    Some of my silver were gold screws, so just letting people know to look out for that!
    jovialkitten - 답글
    The Torx screw circled on the left is actually C5
    Jaryn Wickman - 답글
    I found the same. On my Xbox One S, it's C3 and C5 that hold in the hard drive caddy. C4 holds in the optical disk caddy.
    jamesr -
    Yeah, C3 and C5 on my console too.
    Jahn Roux - 답글
    Funny thing on my console rev t t3 built feb 2018 it’s C4 and C5
    KingofRome - 답글
    The instructions fail to mention that the top metal cover can be lifted off at this point without undoing any more screws.
    CityZ - 답글
  7. Xbox One S Heatsink/Fan Replacement: 7 단계, 이미지 1/3 Xbox One S Heatsink/Fan Replacement: 7 단계, 이미지 2/3 Xbox One S Heatsink/Fan Replacement: 7 단계, 이미지 3/3
    • Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
    Do not disconnect the connector in the second image! There are tiny prongs that bend easily and if bent just a tad bit they will break off. I had first hand experience with this and I ended up breaking my Xbox because I could not put that cable back on.
    [deleted] - 답글
    Do not remove the cable!!!! You can change while the cables are plugged. It took 2 hours trying to put mm precisely all the little pins because of the removal of the cables.
    Please update the post, I could easily end up as the Aaron, breaking the XBOX completly.
    Botond Kopacz - 답글
    Yes, this has also happened to me the connectors had broken and the pins bent and snapped off.
    Samuel Garbutt - 답글
  8. Xbox One S Heatsink/Fan Replacement, Optical Drive Assembly: 8 단계, 이미지 1/1
    • To remove the optical disc drive, remove the silver 10 mm T-10 Torx screw labeled "C4."
    The image shows screw 'C4' witch is the correct screw. 'C5' is for the HDD.
    GoJoel - 답글
  9. Xbox One S Heatsink/Fan Replacement: 9 단계, 이미지 1/1
    • Pull the disc drive slightly off the motherboard and disconnect the plastic connectors from the motherboard.
  10. Xbox One S Heatsink/Fan Replacement, Motherboard: 10 단계, 이미지 1/1
    • To replace the motherboard you must remove the three silver 10 mm T-10 Torx screws labelled "C1," "C2," and "C6."
    • Remove the four black 8 mm T-8 Torx screws lablelled "A1," "A2," "A3," and "A4."
    The Black screws are T-8 Torx, not T-9!
    Jakub Krzyskow - 답글
    I didnt see this before, so thankfully I was able to use T9 without stripping the screws!
    Charles Jackson -
    IMPORTANT! You also need to remove the two T10 screws labeled B1 and B2 in order to remove the motherboard! I had to figure this out on my own.
    Charles Jackson - 답글
    I hust had to remove the red ones and than i was able to lift the powersupply of the mainboard
    Dennis M - 답글
    I had to remove B1 and B2 as well.
    Seen Bee - 답글
  11. Xbox One S Heatsink/Fan Replacement: 11 단계, 이미지 1/1
    • Locate the rectangular silver clamp on the opposite corner of the power block.
    • Remove the black bracket near the fan.
    Remember to remove the black bracket by the fan!
    Martin Samuelsson - 답글
  12. Xbox One S Heatsink/Fan Replacement: 12 단계, 이미지 1/1
    • Grab the clamp with the tweezers. Pull the clamp upward, away from the silver casing. Jiggle it back and forth like a tooth if necessary.
    • It's okay to apply a little bit of force here to get the clamp off the silver casing. The metal is bendable and can be bent/clamped back on.
  13. Xbox One S Heatsink/Fan Replacement, Remove Wifi antenna: 13 단계, 이미지 1/1
    • Remove the four black 8 mm T-9 Torx screws labeled "E1," "E2," "E3," and "E4."
  14. Xbox One S Heatsink/Fan Replacement, Remove Mediatek board: 14 단계, 이미지 1/1
    • Remove the three black 8 mm T-9 Torx screws labeled "D1," "D2," and "D3" to remove the Mediatek board.
    What bit couldninuse tontake D1-3 screws off
    Amanda Zapata - 답글
  15. Xbox One S Heatsink/Fan Replacement: 15 단계, 이미지 1/1
    • Now that the clamp is removed, gently lift the motherboard from its edges out from the metal casing. The motherboard should come out with ease.
    They forget, I think, to tell that first you need to take off screw B1 and B2
    Gabriel Varela - 답글
  16. Xbox One S Heatsink/Fan Replacement, Heatsink/Fan: 16 단계, 이미지 1/3 Xbox One S Heatsink/Fan Replacement, Heatsink/Fan: 16 단계, 이미지 2/3 Xbox One S Heatsink/Fan Replacement, Heatsink/Fan: 16 단계, 이미지 3/3
    • Flip the motherboard over to the back and find the metal x-shaped bracket.
    • Use a spudger or plastic opening tool to pry the corners of the bracket off the four little green mounts.
    • These photos show a screwdriver being used to lift the bracket corners. Use a spudger or plastic opening tool to prevent damage to the motherboard.
    Wenn der Kühlkörper gelöst wird muss die Wärmeleitpaste erneuert werden !!!
    Rich Martinek - 답글
  17. Xbox One S Heatsink/Fan Replacement: 17 단계, 이미지 1/2 Xbox One S Heatsink/Fan Replacement: 17 단계, 이미지 2/2
    • Detach the fan/heatsink from the board by gently pulling up on the plastic white connectors.
    You don’t have to take the heatsink off the motherboard to take the fan off if that’s what you’re after, just take a flathead and lift the clips and that should let the fan go.
    therealdeimy - 답글
  18. Xbox One S Heatsink/Fan Replacement: 18 단계, 이미지 1/2 Xbox One S Heatsink/Fan Replacement: 18 단계, 이미지 2/2
    • Once the heatsink/fan is off the board, use the plastic opening tool to pry the plastic fan off the metal heatsink at the fan's rectangular clips.
    • It may take a bit of force to pry the fan off the heatsink.
    This guide and the visual diagrams provided are great but shouldn’t you at least mention destatic process, work matt grounding and the need to replace thermal compound for the sake of novices doing at home repairs?
    Mikey in a jar - 답글
    I agree with the comments, though I am not the author; I repair stuff like this for a living. Making manuals on IFIXIT.com is a dilemma. The manuals are great if you are the repair guy and need some basic help on a new device. But if then again, if you are the repair guy, and you have much experience, do I really want to give away all my hard-earned experience to the average home DIY guy who thinks they can do everything without paying anybody for it? My .02 on the comment by Mikey is that indeed, a cursory mention of "additional precautions/procedures" should be included, but not with much detail. In fact, I think ALL of the IFIXIT manuals abruptly end and should have a disclaimer to the effect of, "THIS GUIDE MAY BE INCOMPLETE. INEXPERIENCED DIYers MAY PERMANENTLY DAMAGE OR "BRICK" THE DEVICE. WE HIGHLY RECOMMEND CONTACTING AN EXPERIENCED TECHNICIAN."
    B. A. Computer Services - 답글
    "Cannot edit comment after 5 minutes past" is very stupid. What if I wanted to correct a typo or logic error? 5 minutes is way too short. After 24 hours maybe... So now the community knows why we do not post much on this forum. And BTW, the laws in California are very different than the laws in other states, so some of the issues that are pushed do not apply at all in other states.
결론
다른 42명이 해당 안내서를 완성하였습니다.
Erik Ramazzini
회원 가입일: 04/26/17
2,749 평판
안내서 3개 작성하였습니다
Cal Poly, Team S22-G3, Livingston Spring 2017 Cal Poly, Team S22-G3, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S22G3
4 회원들
안내서 56개 작성하였습니다
댓글 9개
After researching replacement costs through local "fixit" places and Microsoft and cost ranging from $140 to $175 for fan replacement. Decided to take chance on this fan for Xbox one S. https://www.amazon.com/gp/product/B07HD3... Take time taking the bottom black plastic cover off once it gets started its easy. The corner by MS logo has tab that seems a bit thicker and took some doing to get off. Followed this guide did not have to do port removal. Once I got main white case off I just took hard drive and optical drive screws out. Just lifted enough to get to tab holding fan onto heat sink. popped them off and then replaced with this unit. Be aware when putting optical drive and hard drive back in place there are plastic tabs that match to holes on motherboard and let the two units sit down all the way. Also If I recall the hard drive goes in first and then  optical drive. 15 minutes from start to finish. Worked like a champ right off! thanks for the awesome guide!
Don - 답글
ACHTUNG!!! Schritt 15 ist UNNÖTIG bzw. hat so wie hier beschrieben womöglich FATALE Folgen für Eure Xbox! (Es sei denn Ihr wollt aus irgendeinem mir nicht ersichtlichen Grund den Kühler austauschen und nicht den Lüfter.) Denn was hier unterschlagen wird: Löst man den Kühler wie in den Bildern gezeigt von der Platine wird die Verbindung zwischen Kühleinheit und Prozessor unterbrochen und die Kühlpaste zerbröselt und verliert jegliche Wirkung!
Der Lüfter lässt sich auch OHNE Ablösen des Kühlkörpers relativ einfach von diesem abhebeln. Falls dennoch der Kühlkörper von der Platine abgelöst werden soll/muss (oder so wie in meinem Fall im blinden Vertrauen auf die Richtigkeit obiger Anleitung unnötigerweise entfernt wurde) UNBEDINGT Prozessor und Kühlkörper von der alten Paste befreien und neue Paste auftragen (Anleitungen hierfür finden sich im Netz).
hypokeimenon - 답글
Es rät sich auf jeden Fall an, die Wärmeleitpaste zwischen Kühlkörper und Prozessor zu wechseln (besonders, wenn sie bereits trocken ist und beim Ausbau zerbröselt), wenn man sich schon die Mühe macht und die Xbox komplett demontiert.
Die Anleitung zum Austausch der Wärmeleitpaste gibt es hier:
How to Apply Thermal Paste
macminitosh -
Ach ja: außerdem fehlt in der Beschreibung das Lösen der beiden seitlich angebrachten Funkmodule (in neuren Modellen?) und zwei zusätzliche Schrauben (B1 und B2) müssen auch noch entfernt werden, um die Hauptplatine lösen zu können. ;-)
hypokeimenon - 답글
Regulär alles da. Nur separat aufgelistet
Steven Hering -
completely misses steps of the process. screws B1 and B2 are required to be removed to seperate the motherboard, and you didnt mention removing the power supply at all, its just in one step and gone the next. with the help of another barely helpful guide, i managed to figure out enough of it to get the job done. would recommend you use gifs for certain steps.
Typtyr - 답글
noticed this too i might make a guide with improved steps to help future fixers
Hayden -
Excellent detailed description, which I read after, I had figured it out myself, nevertheless spot on, and easy to follow.
james0sn - 답글
what size fan doser it use as i have some leftover 120mm fans but idk if they will fit
lizzie McDonald - 답글
댓글 쓰기
조회 통계:
24 시간 전: 15
7일 전: 101
30일 전: 509
전체 시간: 58,300
