주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox One S Optical Drive Replacement
필요한 것
  1. Xbox One S Optical Drive Replacement, Case: 1 단계, 이미지 1개 중 1개
    • Flip the Xbox One S so that the bottom of the case is facing upward.
  2. Xbox One S Optical Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
  3. Xbox One S Optical Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Once all of the clips are opened, remove the bottom part of the case.
  4. Xbox One S Optical Drive Replacement: 4 단계, 이미지 2개 중 1개 Xbox One S Optical Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
  5. Xbox One S Optical Drive Replacement: 5 단계, 이미지 2개 중 1개 Xbox One S Optical Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
  6. Xbox One S Optical Drive Replacement, Interior Case Top Panel: 6 단계, 이미지 1개 중 1개
    • Flip the interior case so it is fan side upward.
  7. Xbox One S Optical Drive Replacement: 7 단계, 이미지 1개 중 1개
    • To access the hardware within the casing, you can pop and lift the top panel of the casing. It should come right off.
  8. Xbox One S Optical Drive Replacement, Hard Drive Assembly: 8 단계, 이미지 2개 중 1개 Xbox One S Optical Drive Replacement, Hard Drive Assembly: 8 단계, 이미지 2개 중 2개
    • To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C5, from the backside of the Xbox One S.
    • Some models may require C4 and C5.
    • This will allow the plastic casing surrounding the hard drive to become detached from the rest of the console.
  9. Xbox One S Optical Drive Replacement: 9 단계, 이미지 3개 중 1개 Xbox One S Optical Drive Replacement: 9 단계, 이미지 3개 중 2개 Xbox One S Optical Drive Replacement: 9 단계, 이미지 3개 중 3개
    • Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
  10. Xbox One S Optical Drive Replacement, Optical Drive Assembly: 10 단계, 이미지 1개 중 1개
    • To remove the optical disc drive, remove the silver 10 mm T-10 Torx screw labeled "C4."
  11. Xbox One S Optical Drive Replacement: 11 단계, 이미지 1개 중 1개
    • Pull the disc drive slightly off the motherboard and disconnect the plastic connectors from the motherboard.
  12. Xbox One S Optical Drive Replacement, Optical Drive: 12 단계, 이미지 1개 중 1개
    • Remove the black, flat Torx screw from the bottom of the optical drive.
  13. Xbox One S Optical Drive Replacement: 13 단계, 이미지 2개 중 1개 Xbox One S Optical Drive Replacement: 13 단계, 이미지 2개 중 2개
    • Detach the wires from the disc drive and slide the drive out.
    • If necessary, you can use plastic opening tools to pry the connectors off of the drive.
결론
다른 29명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Andrew
회원 가입일: 04/26/17
5,782 평판
안내서 3개를 작성함
Cal Poly, Team S22-G3, Livingston Spring 2017 Cal Poly, Team S22-G3, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S22G3
4 회원들
안내서 59개를 작성함
9가이드 댓글
Why do you have to replace the motherboard when replacing the optical disc drive?
Alexander Anders - 답글
because Microsoft puts a security code on the motherboard to pair the drive with the motherboard. so if they don’t match, all it will do is read DVDs and not play any games. Depending on the drive, sometimes you have to Unsolder and resolder the wires going to the motherboard. Other times, it can just be a series of clips for 2 cables and a plug.
If you learned basic soldering in High School, it isn’t too hard to solder.
Lawrence -
what do you need to solder, pics please…
Pete B - 답글
Helped me get to the optical drive in order to disassemble it and remove a coin that was blocking the motor (gotta love toddlers). Thanks!
Russ Barker - 답글
Is this what is to be done if the laser unit seems to be faulty?
Sharry Webb - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 106
지난 30일: 514
전체 시간: 43,737
