소개
This guide has only a few simple steps to get to the microphone. However, soldering is required to fully detach the microphone from the headset and install a replacement. Please refer to the soldering technique guide for instructions on soldering and desoldering.
필요한 것
Use the flat end of a spudger to pry out the rubber stopper at the base of the boom.
Using the flat end of the plastic spudger, gently pry the microphone out of its casing.
Desolder the two wires from the back of the microphone. For instructions on how to solder and desolder, please see the soldering technique guide.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 9개
Is a replacement microphone available from iFixit?
They have the microphone for sale
Would it presumably be just as easy to replace the microphone speaker with one from another headset, granted it fits ?
Any mod to make the cable removable?
