이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the battery pack cover.
Remove the two AA batteries.
Carefully remove the sticker or puncture to reveal the screw.
Remove the side handles by wedging the spudger around the side panels.
Pry the side panel by moving the spudger back and forth. You must do this along the entire seam to remove the side handle panel.
There are seven clips that need to be opened to remove each handle panel.
The bumpers are connected by a middle plastic cover that is around the Xbox home button. Remove this plastic piece by lifting the plastic cover over the two pins, pressing the home button in, and pushing the cover towards the top of the controller.
Be aware of the sync button loosely placed under the plastic covering. Ensure it is put back before putting back the bumper/plastic cover assembly.
Remove the current bumper assembly by pulling them off the plastic cover.
Align the new bumpers onto the top of the controller by holding down the triggers and aligning the four pins on both sides.
Set the new home button cover over the micro USB port, push the home button in, and pull the cover over the two pins shown.
De-solder the soldered joints while holding the red and black wires down on the top motherboard.
다른 6명이 해당 안내서를 완성하였습니다.
