주요 콘텐츠로 건너뛰기
Xbox One Wireless Controller Model 1708 Top Motherboard Replacement
필요한 것
  1. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Cover Plate: 1 단계, 이미지 1/2 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Cover Plate: 1 단계, 이미지 2/2
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
  2. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: 2 단계, 이미지 1/2 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: 2 단계, 이미지 2/2
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
  3. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: 3 단계, 이미지 1/1
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
  4. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Tape Shock Motors in place: 4 단계, 이미지 1/3 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Tape Shock Motors in place: 4 단계, 이미지 2/3 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Tape Shock Motors in place: 4 단계, 이미지 3/3
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
  5. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: 5 단계, 이미지 1/2 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: 5 단계, 이미지 2/2
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
  6. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: 6 단계, 이미지 1/1
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
  7. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Directional Pad: 7 단계, 이미지 1/1
    • Turn the device over and remove the directional pad by gently pulling it away from the controller.
  8. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Joystick Caps: 8 단계, 이미지 1/1
    • Pull the joysticks off of the controller.
  9. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Top Motherboard: 9 단계, 이미지 1/1
    • If the rumble motors fall out of frame, the wires may disconnect from the motherboard . The wires will have to be soldered to reattach the motor.
    • Turn the device over and remove the two 7mm torx-6 screws in the bottom left and right corners.
  10. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, De-soldering required: 10 단계, 이미지 1/3 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, De-soldering required: 10 단계, 이미지 2/3 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, De-soldering required: 10 단계, 이미지 3/3
    • Firmly grasp the top and bottom motherboards in opposite hands, then gently pull them apart.
    • The top motherboard is still connected to the bottom motherboard. To fully separate the top motherboard, you will need to use a soldering iron.
    • Warning: Do not attempt to disconnect the shielded (gold colored) connector as it is extremely fragile you will break it. It runs between the two boards.
    • De-solder the shielded cable from the lower board instead of attempting to disconnect the connector. De-solder using micro soldering techniquest.
결론
다른 20명이 해당 안내서를 완성하였습니다.
Lien (Ally) Quan
회원 가입일: 09/25/17
873 평판
안내서 1개 작성함
Cal Poly, Team S18-G3, Forte Fall 2017 Cal Poly, Team S18-G3, Forte Fall 2017 회원
CPSU-FORTE-F17S18G3
4 회원들
안내서 32개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 88
30일 전: 331
전체 시간: 22,852
