주요 콘텐츠로 건너뛰기
Xbox Series S SSD Card Replacement
필요한 것
  1. Xbox Series S SSD Card Replacement, Peel off the sticker coverings: 1 단계, 이미지 3개 중 1개 Xbox Series S SSD Card Replacement, Peel off the sticker coverings: 1 단계, 이미지 3개 중 2개 Xbox Series S SSD Card Replacement, Peel off the sticker coverings: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Before you start this guide, turn off the Xbox and unplug any cables from it.
    • Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
    Where can I get a shell replacement?
    King DK - 답글
  2. Xbox Series S SSD Card Replacement, Remove the back panel screws: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
  3. Xbox Series S SSD Card Replacement, Remove the bottom panel: 3 단계, 이미지 3개 중 1개 Xbox Series S SSD Card Replacement, Remove the bottom panel: 3 단계, 이미지 3개 중 2개 Xbox Series S SSD Card Replacement, Remove the bottom panel: 3 단계, 이미지 3개 중 3개
    • Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
    • This slides the clips out of the slots on the plastic case.
    • Lift straight up and remove the bottom panel from the plastic case.
  4. Xbox Series S SSD Card Replacement, Remove the plastic case screws: 4 단계, 이미지 1개 중 1개
    • Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
  5. Xbox Series S SSD Card Replacement, Remove the plastic case: 5 단계, 이미지 3개 중 1개 Xbox Series S SSD Card Replacement, Remove the plastic case: 5 단계, 이미지 3개 중 2개 Xbox Series S SSD Card Replacement, Remove the plastic case: 5 단계, 이미지 3개 중 3개
    • With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
    • As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
    • The back panel should now settle on top of the clips on the back of the plastic case.
    • The back panel is permanently attached to the aluminum chassis.
    • Do not attempt to fully remove the chassis from the plastic case with this technique. You may risk breaking your case.
  6. Xbox Series S SSD Card Replacement: 6 단계, 이미지 3개 중 1개 Xbox Series S SSD Card Replacement: 6 단계, 이미지 3개 중 2개 Xbox Series S SSD Card Replacement: 6 단계, 이미지 3개 중 3개
    • Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
    • You may need to lift the chassis to free it from the clips on the bottom-front of the plastic case during this process.
    • Remove the plastic case from the chassis.
  7. Xbox Series S SSD Card Replacement, Remove the power button board: 7 단계, 이미지 1개 중 1개
    • Use a T8 Torx driver to remove the 9.5 mm-long screw securing the power button board to the chassis.
  8. Xbox Series S SSD Card Replacement: 8 단계, 이미지 3개 중 1개 Xbox Series S SSD Card Replacement: 8 단계, 이미지 3개 중 2개 Xbox Series S SSD Card Replacement: 8 단계, 이미지 3개 중 3개
    • Use a spudger to pry and loosen the power button board.
    • Do not pry from the bottom of the power button board as it may bend the connector.
    • Pull the power button board straight out to disconnect it from the chassis.
  9. Xbox Series S SSD Card Replacement, Remove the Wi-Fi board: 9 단계, 이미지 1개 중 1개
    • Use a T8 Torx driver to remove the three 9.5 mm-long screws securing the Wi-Fi board to the short edge of the chassis.
  10. Xbox Series S SSD Card Replacement: 10 단계, 이미지 3개 중 1개 Xbox Series S SSD Card Replacement: 10 단계, 이미지 3개 중 2개 Xbox Series S SSD Card Replacement: 10 단계, 이미지 3개 중 3개
    • Use a spudger to pry and loosen the Wi-Fi board.
    • Do not pry from the bottom or sides of the Wi-Fi board as it may bend the connector.
    • Pull the Wi-Fi board straight out to disconnect it from the chassis.
  11. Xbox Series S SSD Card Replacement, Remove the Bluetooth board: 11 단계, 이미지 1개 중 1개
    • Use a T8 Torx driver to remove the three 9.5 mm-long screws securing the Bluetooth board to the long edge of the chassis.
  12. Xbox Series S SSD Card Replacement: 12 단계, 이미지 3개 중 1개 Xbox Series S SSD Card Replacement: 12 단계, 이미지 3개 중 2개 Xbox Series S SSD Card Replacement: 12 단계, 이미지 3개 중 3개
    • Use a spudger to pry and loosen the Bluetooth board.
    • Do not pry from the bottom or sides of the Bluetooth board as it may bend the connector.
    • Pull the Bluetooth board straight out to disconnect it from the chassis.
  13. Xbox Series S SSD Card Replacement, Remove the power supply screws: 13 단계, 이미지 1개 중 1개
    • Use a T10 Torx driver to remove the seven 11.3 mm-long screws securing the power supply to the chassis.
    Qualcuno sa dirmi come rimuovere una vite bloccata che non gira?
    Mauro Belsito - 답글
  14. Xbox Series S SSD Card Replacement, Remove the upper chassis: 14 단계, 이미지 2개 중 1개 Xbox Series S SSD Card Replacement, Remove the upper chassis: 14 단계, 이미지 2개 중 2개
    • Flip the device over.
    • Lift the upper chassis straight up to remove it.
  15. Xbox Series S SSD Card Replacement, Remove the power supply: 15 단계, 이미지 3개 중 1개 Xbox Series S SSD Card Replacement, Remove the power supply: 15 단계, 이미지 3개 중 2개 Xbox Series S SSD Card Replacement, Remove the power supply: 15 단계, 이미지 3개 중 3개
    • Lift the power supply straight up to disconnect it from the motherboard.
    • Remove the power supply.
    Can you please tell whether it is indispensable to use the power supply with exactly the same Revision, S/N and P/N or is the same model number, like 1920, 1921 enough to make it work? Thanks for showing the teardown.
    Ali Taimoor - 답글
  16. Xbox Series S SSD Card Replacement, Remove the fan screws: 16 단계, 이미지 1개 중 1개
    • Use a T10 Torx driver to remove the two 11.3 mm-long screws securing the fan to the chassis.
  17. Xbox Series S SSD Card Replacement, Disconnect the fan: 17 단계, 이미지 2개 중 1개 Xbox Series S SSD Card Replacement, Disconnect the fan: 17 단계, 이미지 2개 중 2개
    • Take care when flipping the chassis over because the fan is now loose.
    • Use your fingers to pull and disconnect the fan connector from its motherboard socket.
    • Take care not to pull on the wires when disconnecting the fan to prevent breaking the connector.
    • This connector may be difficult to remove. A good method to remove it is to shimmy the connector up and out of its socket with a spudger.
    • You may be able to remove this connector without removing the power supply with a pair of needle-nose pliers.
    If you are careful you can also remove the connector by lightly prying from the sides of the connector in equal proportions (left then right then left etc.) using a 2.5 flathead.
    Zachary Stensrud - 답글
    my fan was solder to my board but it broke off i have no idea ho to put it back my power button is missing the power button on the board i need help
    Edwinn du Plessis - 답글
    If you don't know how to soldier you'll need to get a quote from repair man or company to repair it and weight up the cost or watch videos on Xbox S repairs from Ifixit or YouTube Xbox repair videos
    paul drozd -
  18. Xbox Series S SSD Card Replacement, Remove the fan: 18 단계, 이미지 2개 중 1개 Xbox Series S SSD Card Replacement, Remove the fan: 18 단계, 이미지 2개 중 2개
    • Lift the fan straight up to remove it from the motherboard.
  19. 주의: 19-21 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Xbox Series S SSD Card Replacement, Remove the motherboard screws: 19 단계, 이미지 1개 중 1개
    • Use a T8 Torx driver to remove the four 9.4 mm-long screws securing the motherboard to the chassis.
  20. Xbox Series S SSD Card Replacement, Remove the locking clip: 20 단계, 이미지 3개 중 1개 Xbox Series S SSD Card Replacement, Remove the locking clip: 20 단계, 이미지 3개 중 2개 Xbox Series S SSD Card Replacement, Remove the locking clip: 20 단계, 이미지 3개 중 3개
    • Insert a spudger into the locking clip located on the front-left corner of the chassis.
    • This will open up the clip to make it easier to remove.
    • Lift straight up to remove the clip.
  21. Xbox Series S SSD Card Replacement, Remove the motherboard: 21 단계, 이미지 3개 중 1개 Xbox Series S SSD Card Replacement, Remove the motherboard: 21 단계, 이미지 3개 중 2개 Xbox Series S SSD Card Replacement, Remove the motherboard: 21 단계, 이미지 3개 중 3개
    • Grasp the heat sink with your fingers and lift up the front of the motherboard up above the edge of the chassis.
    • Pull the motherboard towards the front of the chassis to remove it.
  22. Xbox Series S SSD Card Replacement, Remove the SSD card: 22 단계, 이미지 1개 중 1개
    • Use a T8 Torx driver to remove the 5.1 mm-long screw securing the SSD card to the motherboard.
  23. Xbox Series S SSD Card Replacement: 23 단계, 이미지 3개 중 1개 Xbox Series S SSD Card Replacement: 23 단계, 이미지 3개 중 2개 Xbox Series S SSD Card Replacement: 23 단계, 이미지 3개 중 3개
    • Pull the SSD card straight out and remove it from the motherboard.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
다른 19명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Robert Boyd
회원 가입일: 02/01/21
29,403 평판
안내서 94개를 작성함
댓글 9개
hello,i wanna ask on the new ssd how we install the firmware?
kostas660x@hotmail.com - 답글
Well it certainly looks like a 2230 M-Key M.2 NVMe SSD. Will it work in a PC? Will non-OEM SSDs work in the Xbox? $100 for 512GB is highway robbery.
James Spinella - 답글
That's why I'm trying to retrofit my 1tb from old xbox one s into my Series S
Southern Viking007 -
Can I take my 1tb hard drive from one s all digital and use it for my Series S?
Southern Viking007 - 답글
The ssd must have the format 2230 M.2 NVMe for it to be valid.
JUAN LUIS GARCIA BRAVO -
where i find the remplace to the ssd card?
Ben - 답글
Hi, I have an XBsS that is not working because the ssd drive caught power surge and I'm unable to clone it, is there any way to install a new drive? Thanks in advance.
osastudios2 - 답글
I know this thread is old, but is there a way I can get the clone files without having an original SSD? Mine's completely fried so I can't get anything off of it
Julian B - 답글
댓글 쓰기
조회 통계:
지난 24시간: 37
지난 7일: 252
지난 30일: 1,471
전체 시간: 54,154
