주요 콘텐츠로 건너뛰기
Xbox Series X Wireless Controller Daughterboard Replacement
단지 전제 조건
이 가이드는 전제 조건 전용 가이드입니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
  1. Xbox Series X Wireless Controller Daughterboard Replacement, Disconnect the antenna cables: 1 단계, 이미지 3개 중 1개 Xbox Series X Wireless Controller Daughterboard Replacement, Disconnect the antenna cables: 1 단계, 이미지 3개 중 2개 Xbox Series X Wireless Controller Daughterboard Replacement, Disconnect the antenna cables: 1 단계, 이미지 3개 중 3개
    • Slide one arm of a pair of tweezers under the antenna coaxial cable connector, as close to the metal head as possible.
    • Lift the connector straight up to disconnect it.
    • Be sure to lift the coaxial connector straight up off of the socket to avoid bending the connector.
    • Repeat the procedure for the second antenna cable.
    • During reassembly, align the connector over the socket and use your finger to press it into place. A tool like a spudger can slide off and damage the surface-mounted components around the connector.
  2. Xbox Series X Wireless Controller Daughterboard Replacement, Desolder the motor connections: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Silicone Work Mat
    $9.95
  3. 이 단계에 사용된 도구:
    FixHub | Power Series Smart Soldering Iron
    $79.95
    • Use your soldering iron to heat up one of the motor wire solder pads.
    • Once the solder is melted, use tweezers to lift the wire away from the pad.
  4. Xbox Series X Wireless Controller Daughterboard Replacement: 4 단계, 이미지 2개 중 1개 Xbox Series X Wireless Controller Daughterboard Replacement: 4 단계, 이미지 2개 중 2개
    • Desolder the seven remaining wires connecting the four motors to the motherboard.
    • When you resolder these wires during reassembly, make sure to solder the red motor wires to the pads marked SQ3 and SQ7. This ensures that the large rumble motors spin in the correct direction.
  5. Xbox Series X Wireless Controller Daughterboard Replacement, Remove the daughterboard: 5 단계, 이미지 1개 중 1개
    • Use a Torx T5 driver to remove the two 7 mm‑long screws securing the daughterboard.
  6. Xbox Series X Wireless Controller Daughterboard Replacement: 6 단계, 이미지 3개 중 1개 Xbox Series X Wireless Controller Daughterboard Replacement: 6 단계, 이미지 3개 중 2개 Xbox Series X Wireless Controller Daughterboard Replacement: 6 단계, 이미지 3개 중 3개
    • The daughterboard is still connected to the main board by a socket.
    • Insert the flat end of a spudger between the daughterboard and the bottom edge of the frame at the location marked on the image.
    • Twist the spudger to push up the daughterboard and disconnect the socket.
  7. Xbox Series X Wireless Controller Daughterboard Replacement: 7 단계, 이미지 2개 중 1개 Xbox Series X Wireless Controller Daughterboard Replacement: 7 단계, 이미지 2개 중 2개
    • Lift and remove the daughterboard.
  8. Xbox Series X Wireless Controller Daughterboard Replacement, Reassembly tips: 8 단계, 이미지 3개 중 1개 Xbox Series X Wireless Controller Daughterboard Replacement, Reassembly tips: 8 단계, 이미지 3개 중 2개 Xbox Series X Wireless Controller Daughterboard Replacement, Reassembly tips: 8 단계, 이미지 3개 중 3개
    • During reassembly:
    • Line up the daughterboard socket to the main board socket.
    • Check that the headphone jack isn't out of position.
    • Check that the antenna cables aren't trapped between the two boards.
    • Use your fingers to gently squeeze the boards together to reconnect the socket.
결론
작성자
1다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
313,851 평판
안내서 729개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 103
